52" rear springs on the front!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Aug 8, 2004.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    52\" rear springs on the front!
    Ok everybody out there with 52" rear springs on the front of their trucks, I need pictures of your spring hangers and shackles. I'm going to buy a pair 52's, and I want to put them underneath the front end of my suburban. What do I have to do to make these fit, and how much lift will they give me, Do I need to add or remove any leaves from the pack. Any tips will be greatly appreciated.
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Re: 52\" rear springs on the front!
    One thing to add, when doing the 52's you have to go crossover also (if your not already).
    here's how I done mine They still aren't finsihed yet, I've been parting out some trucks to pay for the rest of the mods
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Real quick and dirty:
    - About 4" of lift
    - I used the ORD greasable Shackles drilled out the bottom hole to use the bigger rear spring bolt.
    - The front is cake. Remove "L" from behind the body/spring mount and put it in the front.
    - And the crossover is a needed thing.
    - I cut off the ends of the old lift bushing to take up the extra room.
    You can see that I had to cut my "L" down to fit.
    This can be the flex you might end up with. /forums/images/graemlins/grin.gif
  4. muddysub
    Jun 23, 2001
    10,451
    489
    have to go crossover huh? hmmm.. i didnt wanna do that until i got a dana 60. well i could still buy them and wait and do a D60/crossover/52" swap all at once, that would be fun!
    sandman, i see what you did. thats easy, shouldnt be a problem at all. will a stock bumper still bolt on with the spring hangers relocated like that??
  5. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    yes, you have to go crossover since your axle will move forward 2 inches. you only need to remove the overload leaf.
    as for the resulting flex...
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have no idea. I have heard that you have to modify your brackets though.
    I left the overload in. With the BB and the winch and stuff I thought it might be best. I also wanted to control the axle wrap some. Looks like removing it can make a bog difference!
  7. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    which springs do you use for this? are they off a newer 1/2 ton? 2wd or 4wd? and do you have to move the rear shackle, or just use a longer one in the stock position?
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Stock Blazer rear springs. The truck spings are longer. Mine came from an '88 or so. You will need a slightly longer rear shackle.
  9. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    Could you add a leaf or 2 to get more lift. Has anyone done this. Can you get up to 6" of lift without seriously affecting the flex.
  10. micah
    Sep 18, 2003
    374
    Austin, TX
    my spring with the overload removed give me about 4 inches or more... so i'd think a zero rate and an overload would be good for 6 inches. /forums/images/graemlins/dunno.gif
  11. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Sandman, have you tried pulling the cross bolts from your leaf packs to let them fan out more on the droop?
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have not. At full droop the shocks are about done ( I can move them down a few inches and still be OK on hte stuff) and the brakline is about also done ( I could also do something about that as well). I basically just threw them on and went. I have trashed some rear springs by over flexing them so I decided to play it safe and just go. I might change my mind in the future. /forums/images/graemlins/grin.gif
  13. GRAYTEXK5
    Jul 23, 2002
    281
    Ft. Worth, TX
    could you use rear lift springs for this...maybe like 2" EZ rides, for about 6" of lift, and still have good flex? or would that kill a lot of the flex? and would it cause any other problems running lift springs?
  14. muddysub
    Jun 23, 2001
    10,451
    489
    ahhh yes i was wondering the same... i ned about 6-7".
  15. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I will let you know in about a week. I am getting ready to use an aftermarket lift spring to keep my 7" lift height. /forums/images/graemlins/thumb.gif
  16. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I had kinda thought about using rear lift springs to keep a little heigth. Heck with it though. I'm gona go back to stock springs for the 4" and stuff 44's in there one way or another.
  17. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think 44" are doable. I believe I could fit 42's now and with some firewall work, I bet the 44's would make it. Nicer drivelines angles are just a bonus. /forums/images/graemlins/grin.gif
  18. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Gots to order some bushings for my factory springs. That's pretty much all that is holding me up.
    I like what its gona do to my drivelines, specially with that HP60 up front. Should almost be a straight shot /forums/images/graemlins/thumb.gif
  19. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I did the 56" Spring Swap (more or less the same, just longer "tail" end of the spring) and I have 42's. They seem to be fine. Moved the axle nicly away from the firewall. I haven't put my inners back in yet, but I imagine I'll be able to get at leasy 60% of the inner back in. I intend to bridge the remainder with rubber matting to the firewall.
  20. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thata good to hear. I wanted my next tires to be 42" Iroks. /forums/images/graemlins/cool.gif
