52 spring swap help please
Discussion in 'The Garage' started by warrior454, Nov 6, 2005.
  1. warrior454
    warrior454 1/2 ton status Premium Member
    Jul 22, 2004
    101
    13
    ontario canada
    done the swap unfortunatly i havent done crossover steering yet
    anyone have ideal or come up with a solution to solve the left turn
    issue? Thought i would just use 2 short rods since i have an extra but
    forgot its left hand threaded
    Thanks in advance for any help ya can give
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    try using a limiting strap on the driverside to keep the draglink from goin too crazy until you can do crossover. i used to want to do crossover when i do my 52'' but i deceided on full hydro instead
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    You should be able to use two short sides, I ran with two long ongs for a few years. If you need to be shorter grind one of them, not going to work well on the trail but will get you by untill x over is in the budget
