52'' spring swap opinions
Discussion in 'The Garage' started by nstarry, Oct 8, 2005.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    Hey I know how the search button works !!! to get that out of the way
    my question is I am installing 52s in and I have the 7 leave leaf packs from a 75 3/4 ton and in all the post I see people will say they left the overload or romoved it ,I dont run a swaybar and wont! this is a daily driver though so whats your opinion on how many leaves I should run ? overloads or not ? I want the flex just would like some stability on the road
    I am also putting 2'' longer shackles in the front (front-front ,front-rear)while moving the whole thing foward 2''(axel) total 4''
    74 blazer
    14bff 410 gears
    dana44 front 410s
    36x14.50x15
    rear has shackle flip with 2'' blocks, total 6 1/2 ''
    front now has 4'' roughcountry springs 48''
    Thank you for your help :bow:
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If ya move the axle forward, crossover is required. Keep that in mind.
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I'd just experiment with it, myself. Try it the way it is perhaps, for starters, and if it's too stiff, remove a leaf, and try that. You'll have to replace the center pin if you start with less and go up. But, taking leafs out will mean you can just trim off the pin. Taking out too much just causes it the packs to sit too flat. They are still flexy that way .. but don't provide the lift that most want with it. It may take some fine tuneing ... and a few center pins .. but it may be the best way to get what you're looking for.
  4. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    just machined the knuckle trying to find a tie rod from a 83 or newer rig rite now, and talked my boss into buying the reamer for the jeep pitman arm
    wich brings up another question will I still need to do crossmember work if I move everything foward ?
    sorry for saying that word (heep)
  5. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
  6. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    If its gonna see lots of street miles... the more leafs you have the better IMO. What shocks do you plan on running? some really nice monotubes might help a bit...
    j
