52" Spring Swap Question
Discussion in 'The Garage' started by Bowtiedad, Jul 7, 2005.
  1. Bowtiedad
    Bowtiedad Registered Member
    Jul 7, 2005
    19
    Rochester, Indiana
    I would like to do the swap to my 81 half ton that i just bought from a guy in Arkansas. He had put 4" blocks and longer shackles on the front. I dont beleive they are safe as well as anybody else. My question is do the springs have to come from a 4x4 or 2wd. This mod is something new to me. I was just going to buy springs from BDS or Tuff Country but i saw the mod and it intested me. Any help would be appreciated.
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    don't think it matters what they come from, so long as they are 52" long and in servicable condition. If you have any other questions not covered in my write up, lemme know!
    j
  3. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    Thanks for the quik reply and great job on the write up. It is easy to understand and follow. I will look you up if i have any problems . Again thanks
  4. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    the big diffrence is not in the springs. its in the rear hangers. all have same part # but the 2x4 or 4x4 hanger is what does it.
  5. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    so it doesnt matter if it is 2 or 4 wheel as long as they are 52"..np
  6. sweetk30
    Nov 1, 2004
    25,552
    546
    10-4 big buddy. you are correct. but there is some versions with 3, 4, 5 leafs plus the overload leaf. most use the 5 leaf plus overload packs. part#22-553 is the spring # that any spring shop will know that seles springs in your area.:wink1:
  7. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    how many leafs are used most commonly for the swap? 3,4,5 and overloads if used to get the 4 to 4.5" that jekbrown got with his swap. How many leafs did you use in your swap jekbrown? Sorry i just realized you said most use 5 leaf packs.
  8. sweetk30
    Nov 1, 2004
    25,552
    546
    go to the technecal section. he did the swap and the whole thing is in there. great write up.:wink1:
  9. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    number of leaves you want to use can/would depend on alot of factors, including engine sbc or bbc. winch/ bumper :dunno: i am running 52's with 6 leaves with no overload!( 2 from a 3" stock lift)
  10. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    Thanks for the info.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    my 52 packs have 6 leaves total. Pretty sure they came with 6 leaves. I did remove the overload and replace it with a short leaf from another set of 52s though so it isn't quite as tall as a factory 52" spring pack would be. I did this for the reasons I outlined in the write up... clearance for my tie rod being primary.
    j
  12. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Are you saying that he had 4" blocks on the front, or the blocks on the rear and just long shackles on the front? If the truck has blocks on the front, please to the world a favor and go back and hit that guy in the head w/ a tack hammer.
    My 52's came out of the rear of a 86 K5, but I removed the add a leaf and added a middle leaf out of a pack of 6" Skyjacker springs... I needed more tierod clearance.
  13. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    I am saying the guy had blocks and longer shackles in the front. I wont call him a idiot because of the blocks up front.They maybe legal in Arkansas but i dont think they are here in Indiana and i know they definitly are not safe.Hey jekbrown what hieght lift do you think yours is comparable to? Is your front end very stiff riding using 6 springs? Some of the brand name rearched springs ride like log wagons.
  14. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I have about 4" of lift up front. They are very flexible... I haven't maxed them out yet though because I have no shocks and I still havent installed bump stops, lim straps etc. My front driveshaft is going to be sent home to Jesse to be lengthened also. Anyway, because of all that crap I don't have much info on how they perform yet. I'm not to worried about it, Im sure they will be 100x better than the STIFF AS HELL rancho HD 4" springs that used to be on there. If the 52s dont do it for me, I'll just throw a set of 56s in there. ;)
    j
  15. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    thanks jek, iwas just curius. I am going to go ahead with the install and hope the height it gives me is about the same as it is right now. The truck is only 1/2" lower in the front than the rear and i like the way it sits. Again thanks
  16. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    not a problem. Ya know, if you are gonna run normal low-steer type of steering set up, there is no reason why you couldn't add a leaf or two to your 52" pack to get a little more height if you need it. The only reason I kept so few leaves was to clear my tierod.
    j
  17. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    Thanks jek. I think i will adjust the height if i need to. I will start out using 6 leafs first.
  18. CheyenneKid
    CheyenneKid Registered Member
    Jan 12, 2003
    41
    52" Spring Swap
    I had many of the same questions after reading the article. I have a set of "nicely worn" 5 leaves from a '77 2wd Blazer (yes, they existed!) that were so flexy, i couldn't change tires opn that truck with my Hi-Lift. The bumper would get about as high as my nipples and I would get scared and one more click on the thing would cause it to fall right off the jack. I plan on pulling them from my '77 junker, popping them in my TBI '79, and adjusting the rear lift with a combination of homegrown shackle flip, (fabricated, not ground) and shim. It's just too bad there isn't some kind of equation to determine lift height from spring rate with this kind of mod. Seems really cool, though!
    Good luck!
    Should be a flex monster.
