52" spring swap??
Discussion in 'The Garage' started by 85mudblazin, Aug 4, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    52\" spring swap??
    I have tried the search and we all now that sucks so here is my question, I want to swap in 52" springs up fron and I was wondering if I have to do anything major to the steering since it moves the axle?? or do I have to go crossover?? also how do you mount the 52" springs up front, can I just get a longeer shackle and have it lean towards the rear or is this not acceptible??
    -Chris
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: 52\" spring swap??
    You can search zcarzar(sp?) sandmans and jjlaughners post.
    You need to swap the front spring hanger mount forward and then make a longer shackle.
    Most go to crossover do to the flex you will get out of the springs.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    What can I expect to pay for crossover steering for a front 10b??
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    between knuckle work and box(or shaft) and both arms and drag link...I have $300 into mine.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    thats not to bad, where can I get this stuff?? ORD?? Also what all has to be machined??
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    a flat top knuckle needs to be milled and drilled to be able to bolt the crossover arm on it. a ford pitman arm is needed for the 2wd box(or 2wd shaft)
    I got my arm off ebay and the 2wd box at the junkyard.
    the drag link I got from Sky-manufacturing.
    I'd check with ORD, Sky or piece it together.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    can I mount them without moving my front shackle mount?? if so how much will it move my axle back?
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    frotn shackle stays int he stock spot, just the front spring hanger moves. if you don't move them you'll be like 1" back, which if you add a zero rate you can end up at 5" lift and .5" forward. with out having to move anything.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thats what I was thinking about doing just to make things easier. plus I need all the lift I can get since I plan to go to 38" tires.
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Don't forget your putting a 2.5" wide spring where a 3" wide spring fits.
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    The springs themselves are the same width. The the bushings that are different. The stock front bushings are wider than the stock rears. THe rears don't have any bushing sticking out wider than the spring. You have to either build shackles narrower, or cut off that part of an old front spring bushing to compensate.
    You can also search my posts. I have ALOT of pictures.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I guess that is what I was trying to say but couldn't get the right words out my fingers. Either way you need to compensate. /forums/images/graemlins/thumb.gif
  13. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I just finished hanging mine, for the bushings i called Stephen at ORD and he sent me exactlly what i needed to make it work, i allready had his HD shackles and they worked out as well. If you do not have a 60 and want x over do a google search for shakerbuilt he has just about everything you could need /forums/images/graemlins/thumb.gif
