52" spring swap ?
Discussion in 'The Garage' started by MetalMelter, Oct 8, 2006.
  1. MetalMelter
    MetalMelter 1/2 ton status
    Jan 20, 2006
    401
    EARTH/COLORADO
    Anyone know how much lift i'll get up front? Springs seem to be in good shape, they came off a 1/2 ton(5 leafs+overload). Took them clear apart and sanded, primed and painted.Cut overload down to 7" then reassembled.
    Running a worn out 4" lift know. Lots of sawsall and 37" Pro Comp XT"s.
    Fine on the street, Still rubs with flex. Can you tell me where to go on the site to find before and after picts? Thanks from colorado:D
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Approx 4" of lift, results can vary. Check out the write up in the Tech Articles section.
  3. MetalMelter
    Jan 20, 2006
    401
    EARTH/COLORADO
  4. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
  5. MetalMelter
    Jan 20, 2006
    401
    EARTH/COLORADO
  6. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    do a search, there is tons of info out there. it will also move your axle forward.
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  8. MetalMelter
    Jan 20, 2006
    401
    EARTH/COLORADO
    Just what i was looking for, thanks for the link and the info....
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    No problem
