52" Springs Lowered My 3/4 Ton
Discussion in 'The Garage' started by crazyhole812, Oct 17, 2005.
  1. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    got the swap done this weekend. now my truck sits about an inch lower than before. i even have the zero rates.
    before meaning when i had standard length rough country 4" lift springs.
    when i rotated the shackle mounts i was sure to keep them as close to the bottom i could. i did everything just like the write up said. what's up? any ideas?
    i'm thinking of getting some 2" lift 52" springs. good idea? will they still flex well?
  2. crazyhole812
    Jul 6, 2005
    228
    missouri
    No input? 2" lift springs? will they flex as well?
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    The 2" springs, being arched more than stock height ones, will pull the shackle foward and make a more vertical shackle angle, which will cause a little more lift than the advertised height on the spring.
    I never got to flex out the 2" springs I had on my truck for the very short time they were on there, but I would immagine they were almost as flexy as stock ones.
    Make sure you get a soft lift spring. A 2" Rough Country spring won't flex the same as a 2" BDS or Tuff Country EZ Ride
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    how many leafs in your current 52 pack per side?
  5. crazyhole812
    Jul 6, 2005
    228
    missouri
    thanks Mike.
    i think that's what i'll try. the E Z Rides
    just wish i didn't need to buy another set of springs
  6. crazyhole812
    Jul 6, 2005
    228
    missouri
    don't remember how many leaves. they were the lighter of the two from JC Whitney
