52" springs?
Discussion in 'The Garage' started by shaun, Mar 23, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    52\" springs?
    Some one please explain this to me. Is this just your stock unlifted rear springs put into the front. How hard is it? How much benefit? Flexy? And this gives you 4.5 inches of lift? /forums/images/graemlins/dunno.gif
  2. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    Re: 52\" springs?
    yes this just uses stock unlifted springs in the front, and is super flexy, sorry I cant post pics. to do this I just moved the mount 4 inchs forward and I used 6inch rear shackle for about 4 or 5 inches of lift. the mount sould line up with the next set of holes and move the rear mount that is behind the body mount infrount of it. and you have all the holes you need. Search around there have been serveral writes on this.
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Re: 52\" springs?
    yes that is the concept. Look at the front of the frame on your K5. Take notice of the forward spring hanger mounts and the brace on the outside of the frame. The hanger mount will be riveted onto the lower portion of the body mount and to that brace that is attached to the frame. You have to pop all of the rivets and move the hanger forward. You will bolt it to the two existing holes in front of the body mount. Then bolt the brace to the hanger and drill the frame to bolt the rest of the brace up. You will also have to drill one hole in the bottom of the frame. There are a total of 8 rivets holding each mount to the K5. You will most likely only be able to replace the mounts with 7 bolts. Different years of K5's had different framehorns so the fit can vary from truck to truck depending on year. My `83 was a great fit. My friends `77 took some tweaking to fit well. You will also have a gap inbetween the spring bushing and the mounts. We use flat washers to fill in the gap.
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Re: 52\" springs?
    Let me get this right
    Take rear springs , put them up front after moving the hanger fwd. + longer shackle?
    Then lift rear to match?
    That would be great if I understand this right
    I am new to 4x4 so please excuse my ignorance about them
  5. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Re: 52\" springs?
    Thats pretty much it.
    You can do a shackle flip on the back, which can be damn near FREE and net about 4" lift.
  6. shaun
    Apr 22, 2003
    745
    Re: 52\" springs?
    How much longer of a shackle do I need for say 6 inches total lift in the front? How does this work for daily driving. I have the shackle flip in the rear and at times when I give it gas I can here a loud noise coming from the back of my truck and I am being told it is the shackles loading and unloading is this true and if so would I have this same thing happen in the front. Does anybody have pics of the new front mount setup? I think this is next on my list? /forums/images/graemlins/thinking.gif /forums/images/graemlins/k5.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  8. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: 52\" springs?
    So you just switched sides on the hangers correct? Drivers side went to passenger and visa versa?
    Bill
  9. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    Re: 52\" springs?
    if you want 6 inches of lift go get some 2 or 2.5 inch rear springs and put them up front /forums/images/graemlins/thumb.gif
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: 52\" springs?
    Bill
    I was thinking the same thing, until I looked at this picture:
    It looks like the bracket that you see to the left of the body-mount is bolted to the hanger (ie, it was de-riveted from the right side of the hanger and bolted to the left side)
  11. shaun
    Apr 22, 2003
    745
    Re: 52\" springs?
    So the I can expext about 4 to 5 inches out of stock springs?
  12. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: 52\" springs?
    I got 4.5" of lift on mine.
  13. heavy4x4
    Aug 28, 2002
    3,270
    Re: 52\" springs?
    What did you do with the rear shackle? Just lengthen it?
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: 52\" springs?
    I already had Off Road Designs Greasable shackels so I drilled out the holes in the lower ends to fit a 9/16 bolts and used some Grade 8, 5" bolts to hold it all together. Instead of using washers to fill in the bushing gap, I cut the ends off of the old bushings and stuffed them in there.
    You will want to go to crossover steering as well as the draglink may not go that short.
  15. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    Re: 52\" springs?
    i am fixing to do this swap as soon as i get my ford steering arm in for my crossover steering. the only question i have is will i have to lengthen the front drive shaft since it moves the axel forward. if so could I use the add-a-leaf to move the axel far enough back to make up for the difference. Then at a later date use the add-a-leafs to go more forward and then lengthen the drive shaft when I have more $$$$ for the increased distance. Thanks
