52" Swap Shock Relocation
Discussion in 'The Garage' started by crazyhole812, Oct 4, 2005.
  1. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    it seems that everyone uses ford shock mounts. are you still using the factory mounts on the axle? will the scocks bind on compression because of the different angle of the mounts? i'm having trouble picturing it in my head.
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I'm runing the superduty towers and the bushing angle isn't ideal but it doesn't seem to be binding or affecting flex at all
    Mike
  3. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    My shocks seem to bind up just a bit on compression, but nothing severe. As far as the holes for the towers, I just positioned the top shock mount in the middle of my 14" shocks travel and it turned out nearly perfect. Overall, it's worked great for me but I still need to tweak my lower shock mounts a little bit.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have the stamped ones. Set them up for 5" of uptravel and 10" of droop. Work good. I cut the mounts off the D60 and just welded on some tabs.
  5. crazyhole812
    Jul 6, 2005
    228
    missouri
    did you weld the tabs on top of the axle?
  6. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I'm using the stock axle shock mount with no problems.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    when I got my d60 it did have shock mounts on it. The tabs are just welded where the stock ones were on the side of the axle but they sit closer to the tube.
  8. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Same here...
  9. crazyhole812
    Jul 6, 2005
    228
    missouri
    thanks guys
