52"to 56"- hangers ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Feb 14, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    52\"to 56\"- hangers ?
    are 52"and 56" hangers both all the same ? just in forward holes* ?
    checking before swapping 14 bolt under in placeof the 10 bolt, want to convert to 56" while im at it, i already have a pair of 56" mains, just hoping 52" hangers are same.
    thanks for anything
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Re: 52\"to 56\"- hangers ?
    what do you mean by the same? i just finished putting 56" springs on mine yesterday.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Yes they are the same, just have to move the mounts back 4" along the frame.
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    or use the shackle flip and swap sides with them and drill an inch and a half back. ;]
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Or use the ORD flip, swap sides and add a longer shackle and while you're at it throw on a set of speghetti springs AKA Ford57's
    or like my Buddy's 86 long bed. the previous owner put 56" in a 52" set by using 2 stock shackles linked together. You lose 2" of lift doing that (or gain 2 more depending on spring and shackle set up (flip VS. non flip)
    -Jeremy
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if you done drill the holes back with the flips on opposite sides, then the angle will be too much = wheel hop like a mofo
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool deal,
    ill just move em back and bolt em on using rear holes /forums/images/graemlins/laugh.gif
    thanks
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I've done this, and on my frame the factory had put holes in the rearward positions already so I just had to enlarge them for the bolts. IIRC, the bolts were closer to 3" back, not 4", which I thought was a bit odd. If you're truck doesn't have the factory holes in the farther back position, make sure to do some measuring of other trucks before you start drilling.
