52" under a '69 chevy 1/2 ton
Discussion in 'The Garage' started by blacksheep10, Mar 10, 2005.
  1. blacksheep10
    blacksheep10 Registered Member
    Feb 16, 2005
    37
    Paola, KS
    I am doing a 52" conversion on a 69 1/2 ton and putting a 60 and 14 in it for the guy while I am at it. I am curious how far forward you guys moved your front perches to make the tire sit in the factory position in the wheelwell. He is not a fan of trimming or an uncentered wheel. Still drives it to work sometimes and such. I currently have them moved 4.5" forward and the rear shackle perches moved 2.25" back and a 7 inch shackle. Isn't on the ground yet, wanting to know what is might look like (still dont' have u bolts and other goodies to set it down with.) Will the tire be centered?
    rear leaves are 1974 1/2 ton 4wd rears with the overload still in it.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    what length front springs came in that truck? are they the same as 73-91 front springs?
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    No.
    I am gonna keep an eye on this thread too...so I have some options.:D
  4. blacksheep10
    Feb 16, 2005
    37
    Paola, KS
    rough shot with the tape looked like 44ish. Didn't get super technical. Figured with 52's I could move the front perch forward 4.5 inches ( a half inch too far) and then with the 7 inch shackles they would flatten out some. Sure, still a half inch forward, but if you trim, I think you want to trim the front of the fenderwell. The truck's name is tetanus, kind of rusty. Those fenders just don't look as good trimmed. I just bought u-bolts, should have it on the ground in about 20 minutes. will try to get pics on here.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    check this out...I think its pretty tasteful:
    http://pg.photos.yahoo.com/ph/portal2hades/detail?.dir=1e30&.dnm=bba5.jpg&.src=ph
    iirc, thats a '68 body on an 80's K20 chassis...thats why the front wheel is so far forward. its not mine, I stole the pic off of the 67-72 board.
  6. blacksheep10
    Feb 16, 2005
    37
    Paola, KS
    yes, but you might notice that the center of the tire doesn't fit with the center of the arch of that fenderwell. It is a constant arc on this body style. On the next gen after this one, the shave is painless, not much of a big lip on the fender to look goofy once it is gone. He wants to one day make this truck nice:surepal:
    Like I said, its name is Tetanus.
    anyway, with it on the ground, it looks like the tire is about 1.5 or less forward. Not too bad, I think I can convince a small shave job to make it look right. If not it is back to the torch and welder.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    is it an option to use a 0 rate, to push the axle backward 1.5"?
