52" up front without moving axle?
Discussion in 'The Garage' started by Geargrinder, Jul 27, 2005.
  1. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I did a serch, but couldn't find the anser I need. Can I do the 52" spring swap without moving the front axle forward?
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You would have to redrill the centering pin hole in the spring many people will tell you this will weaken the springs and not to do it but I have done it many times and have never seen a spring crack where either the old or new holes were. Also spring steel is hard very hard you will need several new drill bits and a drill press if you don't have these dont even think about doing it
  3. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Why would you want to put in 52's without moving the axle? The other solution would be to put in a zero rate and run it backwards so the axle would only be forward 1/2". If you are trying to make the stock steering work with them good luck :doah:
  4. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    i worked at a spring shop. was told never never put more than 1 pin hole in spring. will break there first.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    If you dont move the axle forward your tires going to be in your fender well real quick. if your worried about looks just cut that tab under the marker light off and you cant tell the differance.
  6. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    That's exactly what I am doing. I am using a zero-rate to push the axle back 1.5". That's only a 1/2 inch forward from stock. It works great for locating the axle. However, it's still no cure for stock steering (speaking from experiance).
  7. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    52" spring swaps and stock-style steering... not a good idea.
    j
  8. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    What he said ^^
  9. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    To tell the truth I haden't even thought of the steering yet :doah:
    I am more conserned about the stock drive shaft, not the looks or the steering. I have been using the stock front 'shaft on my '86 (w/6") fore years without ANY problems :eek1: and was hoping to do the same on my '84 with 52's up front :o
  10. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    cuttin tourch and a welder you can do anything. but i too have wondered why you need to move the axle. why not just build the mounts so the axle is in its original locaton?
    balzer
  11. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    moving the axle is half the benefit of the 52" swap... by moving it forward your approach angle is better. Naturally, the other benefit is flex. Personally, if I had stock style steering and didn't want to move the axle at all, I'd just buy a good set of stock-length leaf springs. TC EZ rides would be a good choice... they are flexy and you won't have to mess with any of the poopoo related to 52" springs. IMO its only worth it if you are looking for both more flex AND axle relocation.
    j
  12. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Just face it that front shaft isn't going to cut it with 52's up front they have too much travel. You will need to have it retubed but that is 50-100 so not worth the hassle IMO just get the right length shaft and crossover steering. The benifits of having the axle forward far out weigh the problems of the driveshaft cost.
  13. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    What the heck are you trying to accomplish with the 52's??
    I think you might want to be sure about your objectives....because it's about to open a big "can of hurt" on your truck if you don't think it through first.
    Steering Mods / Axle position / Driveshaft length / Brakeline Length/ Sheetmetal clearance (on both sides of opening) / etc / etc.
    Adding massive flex is going to screw up everything "stock" about your front end, so unless you're prepared to deal with all of the associated changes too....it may just end up making you miserable.
    Oh yes, and if it's your "driver"....you may not like the wallowy feeling that soft front springs are going to give you. :eek1:
  14. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    When I put 52's up front, I needed the following changes to the truck to accomodate:
    Crossover steering
    Steering frame reinforcement bracket from ORD (You don't want to do crossover without this)
    High Angle Driveline
    Fender trimming
    "Taller" upper shock mounts
    Longer travel shocks
    Unless you're prepared for all of those associating modifications, you should consider something else than 52's.
    -Mike
  15. padrik5
    padrik5 Bike repair man
    Mar 13, 2004
    37
    Bremerton Wa
    are you going with the 52s to get a 4 inch lift ?
    or flex
    i have a 5 inch lift for 100 bucks if you want it than you can stay with the stock steering
  16. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    I'm my oun worst enimie :p: This is my DD, but I can't help thinking that more flex, softer ride, more lift, ect. ect. would be good. But the more I think about it, U all are RIGHT! If I'm not ready to go all the way on this one I should just stick with a "bolt on" lift kit and leave it @ that.
    Thank U all for snaping me back to the real world :bow:
    (after all, I have a TRAIL RIG to this stuff to :laugh: )
