52" vs 56" front
Discussion in 'The Garage' started by tree_entz, Jan 25, 2005.
  1. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    if a post like this exists, please just copy the link for the thread and I'll shut up.
    but I think it would be a good idea for a breakdown of pros/cons.
    Another recent thread had suggested that neither will net 4" (which I had thought otherwise), so matching a 56" spring swap in the back (w/ flip) would be difficult unless you did something like uh... that other dude did by extending the frame.
    I feel like there is a lot of repeats about this subject (cause of questions like this:rolleyes: ) as well as the swap seems to still be expanded upon.
    anyone have a good idea of how to set this thread up?
    I searched, but didn't have luck, so dont grill me too bad. I'm just planning for the spring.
    while we're at it, does anyone think it's worth it to do the 63" rear swap for a full size?
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    if you swap in the 56's you dont have to move the rear shackle mount. but i belive you have to notch out the body mount or the shackle will hit
    i dont know where you got the idea that you gain no lift from the swap, i mean i could see if the springs were really sagged, or a bunch of leaf's were removed, my swap gave me a little more lift than what i had with 2 year old 4 inch front springs
  3. tree_entz
    May 4, 2004
    141
    N. Vermont
    that's where I got the idea from......:thinking:
  4. tree_entz
    May 4, 2004
    141
    N. Vermont
  5. tree_entz
    May 4, 2004
    141
    N. Vermont
  6. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    that post like 3 posts up in the quote was in one of my posts. And I do not see why the 56" springs would not give a 4" lift the same as the 52". I do not know if the 56" have as much positive arch as the 52" but I am sure they are a thicker pack also. Plus if you think about it 4" difference over the 48" neg acrch may not have the same look on a longer spring pack like the 56". the 52" would have to have more pos arch to get up to the same hight as the 56" w/o quite as much overall.
  7. tree_entz
    May 4, 2004
    141
    N. Vermont
    OK, i did some more searching and found most of what I need. I'm a detail freak, so i'm sorry if I ask questions that have been covered already, but please
    spare me 2 more:
    -do the 56s up front move the front axle forward more than the 52s....
    i'm concerned about too much WB.
    -will the 56's use the same location as the 52s (moving the spring mount [not shackle hanger] forward)???
    thanks in advance.
    werd
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    Me too! :waytogo: Best way to learn is to ask questions and lots of them :grin: I believe I read that the 56" springs are 4" longer in back of the spring perch. Not positive though
  9. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    i belive that the axle will move foward the same amount. ill let you know for sure cuz im gona swap out the 52's for a brand new set of 56's
  10. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    48" spring have a centered pin. so do 52"s. do when you go to a 52" in the front, you can get 2" more WB depepnding on where you mount it. the 56" have a 26" side and a 30" side. this is because the applications that use these springs dont move the front mount, just the rear. and the axle is in the same location. 52" and 56" may have a similar arch, but because the 56" is longer, it will net more lift. if you set them on the ground with the eyes on the bottom and the pin up in the air, the 56" would rise over the 52". if they had the same arch, they would be concentric circles if you know what that means.
  11. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    the guy that says your not going to get at least 4 inches of lift from 56s is wrong.
  12. liv24wheel
    liv24wheel Registered Member
    Jan 20, 2005
    64
    Albuquerque, NM
    If you have cross-over steering with Redneck ram, what will happen to the steering if you do 56" springs and the axle is moved forward x-amount of inches? Will it all be fine and just move with the axle?
  13. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Here is my view on this because this is how i did mine.
    I placed the long side foreward and kept the original rear shackle location stock with 5" long shackles. I have crossover and hydro.
    I just recently got to drive it on the street for the first time and it felt real soft. not unbareably soft but soft.
    I have 38's and belive to lift to be 4"--i dunno--you tell me.
    I haven't done any real testing on this but as soon as the front shocks come in it will be soon after that.
  14. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    It looks good couple q's is 5" shackles long enough???? my eyeball calipers have said somewhere around 7.5" and does your front mount locate the spring the same as moving the stock mount forward? also do you think 56'' springs would be to soft with a Bigblock?
  15. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    56s will move the front end forward the same amount of 52s. The short side of the spring is (usually) mounted forward, and its equal in length to the 52s.
    IMO this is one of the cool thing about 56s... the offset center pin gives you flexibility in mounting. In the rear suspension, for example, you can get 4" of extra wheelbase... if you want it. If you don't, just spin them 180 degrees and bolt 'em on.
    j
  16. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    these springs are soft, if i were to guess, i would say no. If you really were set on 56's i would probably get at least a 2"lift spring. right now i really have no real world expirence with these other than how they drive down my street a couple of blocks. If i end up not liking them i thought ahead and drilled another set of holes for the 52's.
    here is my shackle angle with the weight on it.
    i think it will work for me right now, but like i said i still need to test it.
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so with the 56's mounted backwards on the front, you keep stock axle location correct? have you flexed it out yet? looks real good. ill be doin 56" swap evetually as well
  18. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Well I'mgonna run 56" springs I'm about 1/2 way through the swap now I'm planning on runnig a Tbi 350 ..... but I'm thinking it may be a bit Anemic for my taste My project is a K20 But the body has been completely skinned out Including the bed floor and I will using 41" Ditch Witch tires the rest of the project is pretty standard CK5 material dually 60 front Th400/203/205 14bolt /dana70 ? rear not sure of it yet I still have many issues to work out But i started with the front suspension
  19. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    yes the axle is in the stock location and I havn't been able to flex it out--hopefully tomrrow (thursday) and of course there will be pics.
  20. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Do you foresee any issues with your front pinion angle?
