52's and 64's pics
Discussion in 'The Garage' started by rubbinz raczn, Jan 24, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    got the 52's and 64's on gonna paint the frame and cab. tomorrow i take the beadlocks down to get welded and to throw the iroks on!:D
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no motor or trans? Me thinks you will be sitting rear high. even if you put a rear radiator and fuel cell your puting more weight on the front end. I could be wrong, the rear springs could be really soft(63s I'm sure they are soft even if lift springs)
  3. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    are those 64's lifted? they have quite the arch to them.
  4. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    hard to tell? the front tires are 28" tall rear are 32" so that makes the nose drop some. i plan on using a zero rate up front so that will help a bit. i will be running a 22 gal. fuel cell and optimas in the rear, also a tube framework to protect them but that in no way will counterbalance engine. also front will be narrowed and just skinned fenders so that will help! the rears are 5" lift but they flex a bunch!:D
  5. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I like the added weight to the rear in the second pic (sitting on the framerail). :D
  6. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    we get thirsty :rolleyes: oh here are a couple pics from today.
  7. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    what is the wheel base on that thing? It looks awfully short.....
  8. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    looks good
  9. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    i moved the front hanger on the rear springs forward 22 inches with the longer springs that nets me 116" the 52's moved the axle forward 2" so i am up to 118" i have 2 sets of zero rates so i was gonna move the front axle forward. so that would be 119-1/2" i don't need more lift in the rear but if i were to use a zero rate in the back that would get me 121" but i think i may just leave the rear be and push the front forward the 1-1/2" and stay with the 118" cloae to the stock shortbed length :D
  10. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I saw that too.....:D
  11. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    man do i love the o.d.g green sweet ride keepup the good work.
  12. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    the frames gonna be flat black. not sure on tube work? beadlocks will be black with od green outer rings. i am alos gonna take 30 inches out of the front grill :D
  13. white-rhyno
    Jan 27, 2002
    942
    man, im at 117" +/- and that looks allot shorter, must be an optical illusion....
  14. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Are you gonna chop the recreational beverage holder off the rear?
  15. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    just went out and measured, 119" like it sits! don't know why it's not shorter but i guess it's not an exact science:D
  16. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    yup! there are 21 inches of frame sticking out past rear spring hanger if i leave 6" 15" goes by by:D i work faster if i have beer ( at home!)
