545 allison tranny?
Discussion in 'The Garage' started by muddybuddy, Aug 15, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    anybody know anything about these? would it work in a k5? a guy is selling one locally (also happens to be on pirate) any idea on what spline output it is?
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Bellhousing will not bolt to a chevy bolt pattern. Plus it has no park. It weighs 289lbs dry. Convertor will not bolt to a chevy flexplate.
    Short answer is no..
    john
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alight cool, jus thought id check it out.
  4. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    Allison tranny's..
    We sold an Allison tranny at the junkyard out of a 70's Chevy chassis School Bus,it had a 350 motor coupled to it..the guy who bought it planned to use it with a divorced NP 205 T-case that we sold him out of an old International 4x4 1 ton truck...note sure what # Allison tranny it was,but he did drive by with the truck a few weeks later--but didn't stop,so we never got to see it all installed and working..then we closed up for good,haven't seen him since..
    I would have liked to have seen it,and heard how he did it!..:crazy:
  5. sweetk30
    Nov 1, 2004
    25,534
    531
    horseheads , ny 14845
    the school bus was a at540 model mostlikly. i have one also. it has a big round bolt pattern on it. then it bolts to a adaptor plate like the cummins have . it uses a beffyer flex plate. and the convertor is the same as a th350/400 but 700-800 stall speed. non removable tail housing tho. it has a park brake on it in the back. and yes no park gear. the shifter is kind of like a art car style. 4 speed auto tranny basicly. non over drive. out of 2.5 ton trucks. i was going to use mine in a crew cab with divorced tcase also.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  7. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I have a 545 in my Motorhome. Its connected to a Cummins 5.9 setup as a pusher and actually drives the differential backwards. Its also connected to a GV Overdrive unit since I have 4.56 gears. Its a 4 speed with a 2000 RPM converter and no parking paw (R,N,D,3,2,1) requires a driveline parking brake or.....The MT-643 is a much better trans with lockup converter.
    I will try an attach a picture of it when I get home this eve.
