56" front springs
Discussion in 'OffRoad Design' started by 85k30, Jan 11, 2006.
  1. 85k30
    85k30 Registered Member
    Jan 1, 2003
    24
    I just read the article on installing 52" springs inthe front of a blazer. They moved the front shackle mount forward 2.75". If i keep the front shackle in the stock location i wonder if 56" would fit? has any body done this?
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Yes people have and if you try searching you will find posts about it.
  3. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    One of the major mags, 4WOR or 4wheeler did a OK job on a write of just such a set-up. They used a custom front spring pack that has a stock length from front spring eye to center pin and all the "extra" length was from center pin back. I run the same style spring from Alcan and works sweet! The one large downfall is that you get all most too much movement and with the tire in the stock location a 38.5 Bog will get into the lower fire wall, so some major hacking is required.
    I looked for a pic of the front of my rig but had none.
    Good luck, Jeff
  4. 85k30
    Jan 1, 2003
    24
    did they move the front spring hanger forward?
  5. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    Nope, just the rear mount back. The rear shackle on the front spring is now right in the middle of the body mount brace. I'm sure that some K5 members will be able to link you to the write-up and do a better job of describing the process to.
    Jeff
  6. 85k30
    Jan 1, 2003
    24
    i remember that article now. if i move the front mount forward just like the 52" or mabe a little more i should be safe
  7. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
  8. 85k30
    Jan 1, 2003
    24
    re 56" springs
    thanks for the threads.
