56" long rear springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Nov 21, 2001.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
    56\" long rear springs
    OK, what's the deal on 56" long springs, what years did they come on and what year did they have the teflon pads? I thought that 73-87 1/2 ton had the 56" but was it just 3/4 and 1 ton? Someone give me the scoop please.
    Steve
    Director of Global Expansion
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Re: 56\" long rear springs
    I believe it is just the 3/4 ton +. I have an 85 1/2 ton and I KNOW that it is 52".
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    OK, what about the 88 (IFS) and up 1/2 ton, did they have 56"?
    Steve
  4. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    Those were 63" I think..
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. CK5
    May 19, 1999
    21,627
    704
    CO
    So if I want 56" long springs, I have to look for 73-87 3/4 ton only?
    Are Ford F-150 1/2 ton springs 56" long, are they the same width as GM?
    Steve
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I remember Marv Springer telling me that the Fords are 57" long and they're a lot softer (flexier) then our stock blazer ones. that's what he uses with his setup.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  7. CK5
    May 19, 1999
    21,627
    704
    CO
    How wide are the Ford springs and are the 57" from an F-150 or F-250?
    Steve
  8. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    Some '73 to '87 half-ton pickups that came with the "heavy-half" option had 56" rear springs,but I have only seen two-wheel drive trucks with this option.
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    The 56" long springs were only on "some" 3/4 tons.... How you tell without getting under there and measuring - I don't know.
    I use "86 to 96" F-150 springs and they are 57" long. Be careful as they come in both 2.5" and 3" widths. I use only the 2.5 inchers. Also, the center bolt is not in the center, and it measures 25" from the front eye to center bolt, and 32" from center bolt to rear eye. I modify them by redrilling to get 26" from front eye to center bolt - which matches the front half of the stock 52" spring.
    Marv
  10. CK5
    May 19, 1999
    21,627
    704
    CO
    Thanks Marv, do you know if the 57" Fords would sit at the same ride height as GM 52"?
    Steve
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Steve, I know the 56" rear springs were available from '80 up to '91 on Suburbans, both in 1/2 and 3/4 ton version.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  12. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    It would be real close..... I can usually build the springs to have 4-6" of lift over stock with my shackle flip. So, I'm sure it would be right in the ballpark there...
    I should caution you that the F-150 springs are way softer than your stockers. I recommend against towing with my system for this reason. After Frizzlefry bolted on my system, he commented that his truck "rode like a car"...! Way flexier - but you trade much of your load carrying and towing capacity.
    I have several sets of these springs lying around. If you have any more q's, fire away!
    Marv
  13. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    Re: 56\" long rear springs *DELETED*
    Post deleted by Liberator
  14. dyeager535
    26,982
    191
    When searching for springs for my K5, I found the longer ones too, but they were always on 2wd trucks. So was it just coincidence that the 2wd ones I had looked at were all 3/4 or 1 tons, or did 2wd's ALL get long springs, and 4wd, at least half tons, got short ones?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  15. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    FWIW, Wes is correct. The key word being "available". Not all 3/4 tons came with them and unfortunately my Suburban is an example. '73 3/4-ton with 52" rear springs. [​IMG] However, the research I've done tells me that _most_ 3/4 ton vehicles come with them.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  16. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Liberator,
    I assume you already have 56" springs? If your shackle angle is anywhere close to vertical, I would think that the extra 1" of length wouldn't be of concern.... but you'd have to try and see.
    Still, there is prolly a difference in the front eye to center pin distance, no? What do the 56" springs measure for this?
    Marv
  17. CK5
    May 19, 1999
    21,627
    704
    CO
    Marv
    Does it matter if the F-150 springs are from a 4x4 or 2wd? How much do you want for a pair? Might be cheaper if I got them locally though, that whole shipping thing.
    Steve
  18. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Steve,
    As far as I know, 2wd and 4wd are the same - 4wd just uses a block.
    Avg price around here is ~ $100 from a wrecking yard. You might do better there, and then there's the shipping cost.
    Some info on donor springs:
    The springs fit 86 - 96 F-150's - and the newer the better. They are 2.5" wide springs (be careful here as many came with 3" wide), and they can be off a 2wd or 4wd truck. The ideal pack comes with 4 teflon padded leafs and 1 overload. Some packs come with 3 teflon padded leafs and one overload - and you can use these, but they will be more work for you as you will have to make and add at least 1 more leaf. You can verify that you've got the right springs by measuring the length: Total eye to eye (along arch of spring) = 57", front eye to center pin = 25", center pin to rear eye = 32". Also you'll want to get a set of springs with bushings in good shape or you will need to install new ones.
    Hope this helps....
    Marv
  19. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Re: 56
    I dont know if it matters.I got mine out of an 88 F150 2x.They have 4 leaves with the teflon pads and 1 over load witch I removed.I paid $100 for them at a yard here.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  20. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Re: 56
    Hey Frizz... how'zithangin'...
    I was hoping you'd show up to comment on ride quality and living with the softer springs!
    Marv
