56"rear spring - normally or backwards???
Discussion in 'The Garage' started by TOMER, Oct 25, 2004.
  1. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    56\"rear spring - normally or backwards???
    Just got the 4" shackel flip from ORD and want to know what flex better with 56",the backwards set up or the normally way ? /forums/images/graemlins/thinking.gif
    (dont need the extra 4" wheelbase)
    OR just stay with the 52"? /forums/images/graemlins/ignore.gif
    thanks
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Re: 56\"rear spring - normally or backwards???
    The 56's will flex alot more than the stock 52's, they will still flex the same backwards or normal, just flip the ORD brackets around and bolt them on, if you want the extra 4" wheelbase run the backwards if you dont run them normal, just remember your driveshaft will change so make up your mind and stick with it. /forums/images/graemlins/thumb.gif
  3. TOMER
    Sep 20, 2002
    38
    Israel
    Thanks.......I'll go with the 56's /forums/images/graemlins/waytogo.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, long side in front will allow more axle wrap and will cause the pinion to rotate downward when the axle droops. And, because the spring perches are on the back side of the arch instead of the front, you'll likely have to run largish shims or rotate the perches to get proper pinion alignment with the drive shaft. Shackle flip will counter some of the angle issues, but I doubt it will be sufficient.
  5. TOMER
    Sep 20, 2002
    38
    Israel
    If I flip the ORD brackets around do I need alonger shackel or I'll be fine with the original one?
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i flipped my ord brackets & moved them back 2"s, i am getting away w/ stock shackles
  7. TOMER
    Sep 20, 2002
    38
    Israel
    I prefer no to move the brackets back , it will affecte my axle droop.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    you wont have to move it back, just flip them side to side and bolt it up.
  9. TOMER
    Sep 20, 2002
    38
    Israel
    thank you all.....
