56" rear spring question.
Discussion in 'The Garage' started by SF87K5, Aug 25, 2004.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    56\" rear spring question.
    Do I need to drill my perches at all like you do with the 57" springs to put these on my K5? I have a echobit flip with extended shackle for them. I am just woundering if I need to do any drilling.
  2. SF87K5
    Oct 27, 2002
    1,105
    Re: 56\" rear spring question.
    can anyone help?
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Chevy 56" springs are the same as 52's, except that the portion of the spring from the axle to the shackle is 4" longer. You can leave everything the same except for the shackle hanger. If you are running stock hangers, they will need to be moved back 5" (to keep the shackle angled back for good downtravel). If you are running ORD shackle flip brackets, you can swap them side to side.
    OR you can do what I did. I used 56" springs turned around backwards to move my rear axle back for more wheelbase and less overhang.
  4. SF87K5
    Oct 27, 2002
    1,105
    Cool thanks for the info. I dont need to move my hangers at all. I am using my echobit flip that is for 57" springs. /forums/images/graemlins/thumb.gif So I already have the fix for my hangers. I just wanted to make sure I didnt need to drill my perches or need a zero rate to move my alxe.
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    the flip and longer shackle is all you need man. Just bolt it up and go /forums/images/graemlins/thumb.gif
  6. SF87K5
    Oct 27, 2002
    1,105
    Sweet thats what I need to know. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
