56" rear springs installed now have shackle questions...
Discussion in 'The Garage' started by k5-newbie, Mar 14, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    I swapped sides with the ORD 4" shackle flip and am running the new 56" springs backwards to move my wheelbase 4" in the rear. Everything went on very smoothly but my shackle angle looks waaaay wrong...here are pics
    Now also my pinion angle is a little low so I need to roll my perches on the 14 bolt, not a big deal. Also, for the guys who have done this swap...did you get much axle wrap?
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I can't really answer your question, but do you have any pictures of the whole truck from the side? You're rear axle is 4" back from stock? Did ya move the front axle at all? And what's your overall wheelbase with all the mods?
  3. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    Kid, the overall wheelbase now is 110 1/2 from 106...My zero rates shipped from ORD this morning and that should move my front axle 1.5" more forward to give me right at a 112 wheelbase. The springs are 4"-56" rears and the fronts are 6" lift. the springs are tuff country and the shackle flip is ORD.
    Oh, and don't ask about the yellow strap around my doors...I put my turbo 400 and 205 case in this weekend and need to build a crossmember :blush: . Its a little rigged but it holds for now LOL
  4. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    funny thing is it dont look moved back to me . but sweet ride
  5. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    From what I understand, you want the angle between the shackle and the spring to be as close to 90* as possible. If that is true, then yours look pretty good. I am interested in hearing from those who know, as my angles are about the same with the ORD 4" plip and ford 57" springs.
  6. sweetk30
    Nov 1, 2004
    25,528
    527
    yes me also . someone please post the pics of the correct angle thanks.
  7. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    Well, what worries me is a buddy and I got up in the back and the shackle completely "collapsed" and stuck straight backwards...three of us had to lift up the rear to unstick it and it finally sprung back up.
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Bhintz just put this same setup on his. Maybe he'll post up with some pics also. BTW I can tell that its moved back. :grin: looks good now you'll just have to trim the back.
    Edit: I thinks some people also added a longer stronger shakle with this setup.
  9. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Hmmm... that doesn't sound too good. Tomorrow I'll go jump around in the back of mine to make sure I dont have the same problem. My gas tank is still out, so if I run into problems, I'll probably move the whole flp bracket to the rear enough to get the best shackle angle, if someone would just post up on what that magic angle should be.
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    are those pics of the shackle with the weight on the truck?? if so then it looks vary good, here are some pics of mine
    shackle angle
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    get rid of the horridly short shackle and it will get a lot better i promise.
  12. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    the shackle angle is as it sits with no top. and if I get a longer shackle, won't that give me more lift??I really don't want to go any higher than it is. I am thinking of moving the rear flip kit back some more on the frame to straighten the shackle out some...just not sure what "proper" angle should be.
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You should make yourself a longer beefier shackle. With the shackle like that you will be dropping on it alot on the trail and stock shackles are not that strong. Also, your angle is fine. It should ride like a damn caddy with an angle like that.
    Harley
  14. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    O.K., I don't think I am illustrating my problem. The problem is that when I stand on the back of my Blazer (I weigh 180 pounds) my shackles completely compress and stick. It will not raise back up on its own. This pic is after I have already stepped off the rear of the vehicle. We had to get three people to lift the rear to get it unstuck.
  15. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Have you double checked the length of your springs to verify they are not mislabeled by the manufacturer?
    Also, have you actually measured your wheelbase? I could be wrong but I think you're only going to net a 2.5" wheelbase stretch with this set up. If you'll notice installing a shackle flip always pushes the axle forward slightly, a Zero Rate installed at 1.0" or 1.5" recenters it. That said, of the 4" push from the spring you should lose an inch or so due to the shackle flip. I plan on doing the same thing you are except I'm going to run a Zero Rate as well (hoping to achieve the full 4").
    I saw your post in the ORD forum so hopefully Dr Watson can clear all this up. :thumb:
  16. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    my wheelbase went from 106 to 110 1/4
  17. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Very cool! I was certain I would need the offset of the Z/R but I really did not want the additional inch so that's good new for me, thanks!
    What do you think about the spring length? Do you think they could be longer than 56"?
  18. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    When I had originally spoke with Dr Watson he was telling me about the 64 inch springs but you have to move both spring hangers and i wasn't feeling too secure about that. Of course it is a proven fact that the longer spring the more flex you get.
  19. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I know longer is better for flex, I was just wonder is your springs might actually be longer than 56" (causing the shackle to flatten out and lock on compression).
  20. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yes... this is a problem that will lead you to a broken main leaf.
    A longer shackle would help, but it would have to be significantly longer... and you may not want that much lift.:dunno:
    I'd say move the hanger back is the best solution. Prolly the reason you're having this problem is maybe your springs are aftermarket "lift" springs and may be slightly longer than stockers... :dunno::confused:
    BTW, ideally, I think you should have a litte bit of that same angle on your finished setup, but that's way too much!
    Marv
