56" rear springs, new or used
Discussion in 'OffRoad Design' started by 79chevyk10, May 2, 2005.
  1. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Will be going to 56's soon to repl. my 52's rear. Noticed that ORD sell 56's that have a lift. Do they offer 56's without a lift that will flex better than anything I can get at the local wrecking yard? I'm running a 4" flip with a zero rates and inboarded rear shocks. Would like to have more flex. I already have a set of 63's but heard that 56's flex like mad without the "land anchor" problems.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your land anchor shackles are there with 56's just not as bad as 63's.
    Harley
  3. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    Anyone?????
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The only thing we could look at is doing some custom springs for you, the TCI's are all lifted. If we go with a new stock spring, the price is high enough on a light rated spring that you're better off with a custom spring. Once you go to a custom spring, you might as well do exactly what you want and you may not end up with out of the box specs for a 56" GM spring.
  5. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i want to run a 8" lift over stock and was wondering if the 4" lifted 52" and 56" springs will give me the same height? i run a 4" shackle flip and i need 4 more inches...and i want the flex so will the 56s work the way i want?
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You could go with either 52 or 56 and get the same height out of them. The only thing to watch is the 56's might sit a bit higher due to a slightly stiffer rate. (they are built for 3/4T's, not 1/2T)
