56" rear springs, what to do to them
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, May 17, 2002.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    56\" rear springs, what to do to them
    I have a set of 56" rear springs with the teflon on the spring ends. They have 7 leaves in them plus the overload. I am planning to take 3 out and flip the overload. What else should I do to them before putting them in?
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Re: 56\" rear springs, what to do to them
    Head down to your local farm supply store and get some black graphite paint and cover your freshly cleaned (wire wheel) springs.
    They use this stuff to protect farm equipment that sits outside for years at a time. Nice and flexible. Works great for Springs!
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Wayne,
    I don't have that much experience with the 56" Chevy's, but I've experimented alot with the 57" F-150 springs.
    I've learned to have a MINIMUM of 5 leaves in the pack. This is the setup I've used for a "flexible" spring pack for a 4" lift. So, I'd suggest the same for your springs... at least 5 leaves.
    Also make sure that your finished pack uses some kind of clamp to keep the leaves aligned.
    Marv
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Is that 5 including the overload? I doubt it is but just checking. I know I need to keep them clamped to keep them inline. I plan to use these springs with your springer kit someday but right now the springer is out of the buget. /forums/images/icons/frown.gif
  5. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Sorry... didn't make that clear..
    That's 5 not including the O/L.
    BTW, if you have acces to some F-150 O/L leaves, they have a little more arch than the Chevy's - so flipping them works a little better cuz they allow more compression (negative arch).
    Marv
  6. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Total newbee question:
    What do those 56"s come out of? What are you planing on doing running them with the pin where it is moving your wheelbase out or just running a longer shackle (which would still lengthen the wheel base depending on where the pin is drilled)? I am looking for a way to get my 74 to flex this seems logical.
  7. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would have to junkyard shop for some Ford springs and these were free. I guess I will try them for now and do the Springer with some 57's if I don't like this set up.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You can find 56" springs in 3/4 and 1 ton trucks. I am planning to leave the pin in the stock location since it is the same distance back from the front of the spring as a stock K5 spring. The difference is they are 4" longer in the rear half of the spring. If you want your 74 to really flex then contact Marv for his springer set up.
  9. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Marv?? ya got a site I can check out?
  10. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Never mind I found it.
  11. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Spooln...
    If you got any ?'s, e-mail me...
    Marv
  12. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I have the same springs in my K/5. I removed two leafs....very soft and flexy set-up.I recently added one of the leafs, it seems to ride pretty good.And I did keep the O/L just flipped it.I've been thinking of flipping the springs where the 30" long side is towards the front to extend the whelbase and increase the departure angle.Oh yeah i did the shackle flip mod(one of the best ideas out there!!!).Mike
  13. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    heres one----i have the ORD shackle flip with the stock springs, but with lowrider extended shackles. the shackles are almost straight up and down, so--- if i added the 56"ers, would it push my shackle rearward so the angle would
    be is a more desirable 45* +/-????
    also, are the early 80's bronco rear springs the same as the F-150 ones?? a buddy just got one and said i could have them.
    thanks rob
  14. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Check to see if the Bronco springs are 3" wide. If so, no worky..!
    Even some F-150's had 3" wide springs. Need to make sure you get the 2.5" wide ones.
    Marv
  15. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    How did those shackles work out, strong? I'm looking at getting a longer shackle (or making one). how much longer are they, were did you get them?
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have heard they are alot weeker then stock shackles. Other guys with bent stock shackles have comented how "beefy" mine look (stock)....
    I think you should just make your own.
