56" spring bushing replacement (part number?)
Discussion in 'The Garage' started by MTBLAZER89, Jun 24, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am in the process of swapping in some 56's and a echobit flip. My question is the little sleeve in the spring eyes. Do they have to be removed? Can I leave them and buy stock bushings? If I remove them what application do I buy bushings for? Last question poly or rubber?
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    most aftermarket bushings require removing the sleeve. Factory rubber ones are prolly the only ones that don't. lol! Poly lasts longer and is stiffer... rubber ones get crusty sooner but are softer. 'sup to you which is most important...
    j
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    agg I got one of these out finally. Those sleeves are really in there. I am removing the sleeve's cause I figure I might as well go to poly while it's apart. Anybody have a part # for their 56's bushings
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    no part number But, I used 1 1/2 dia bushings I had laying around and they fit perfect.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I tried to slide some 1.5" bushings in there, and they are wayy loose. I measure the diameter and it looks to be around 1 11/16's I am guessing maybe I have some of those "metric" 88-91 springs. I need to find these asap, and I want to make sure the part # is right cause I don't have time to return wrong orders. Blazer Fest is coming. 19 days:crazy: :wink1:
