56" spring question
Discussion in 'The Garage' started by k5-newbie, Mar 4, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    I have a 1/2 ton 89 suburban sitting outside my shop. If I took the rear springs out and put them under the rear of my Blazer with the 4" shackle flip will this give me any more lift? Also, will I have to relocate either the front hanger or the shackle flip?
    I did search and did read some threads, but didn't really find the answer to this.
    Thanks in advance.
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    You're not going to get any more lift from the springs (assuming the Sub springs are stock).
    What brand of shackle flip do you have? If ORD simply swap sides with the brackets. The ORD brackets are offset so swapping sides makes the 56" conversion a direct bolt up. :thumb:
  3. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    What vehicles can you find 56" springs in? and how much articulation can you expect to gain over 52's?
  4. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
  5. gm500hprat
    gm500hprat 1/2 ton status
    Feb 28, 2005
    196
    anaheim, ca
    Re 56" springs
    I have 56" rear springs on my 76 gmc k10. I pulled the entire drivetrain off my buddies rolled 73 burb. Direct bolt in with no problems. Even when swapping out the 350 and the th350 for the 496 th400 all i had to do is redrill the tranni crossmember holes and have the lenghts of the driveshaft fixed.
