56" spring steering quesions
Discussion in 'The Garage' started by Masiony, Apr 14, 2006.
  1. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    after reading this thread http://coloradok5.com/forums/showthread.php?t=169666, i have a few theorectical questions about the steering issues. could you run the behind the axle highsteer arm on the pass side, and run the drag link in the back hole, then flip the pitman arm so it was pointing forward? these two motions should cancel each other and create the proper motion for turning the wheel left, and the tires going left too.
    any holes in this theory?
  2. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    all you need is standard reverse high steer double arms from WFO, everything will work fine.
    j
  3. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    just a longer draglink?
  4. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    Actually I think I had to trim an inch or two so off my draglink when I went to reverse/high steer for the 52" swap....
    j
