56" spring swap
Discussion in 'The Garage' started by bshewmaker, Jan 14, 2005.
  1. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    Allright. I want to do the 56" spring swap for the front. #1 I need to know what this spring comes off of. I've heard off of the rear of the 1st gen. of GM IFS trucks. Is this true? and should it be off of a 4x4 or 2x4 version? B. I need to net 8" of lift. I've read the stock 56" rear springs give you 4" of lift swaped into the front. So, if that is correct, I need a 4" lift spring from a 88-98 gm truck. If this is not correct , somebody please point it out. #3. How far forward is this going to push my axle? No fender triming yet, will if needed. is it going to push it way out of center of the wells? #4. I know you have to run cross-over, but I have not heard anybody say if they run hy-steer. Just wondering how much forward can the axle be moved with out the drag-link making contact with the hy-steer tierod?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    88-98 trucks had 63" rear springs. I THINK that the 56's were on 73-87 1 tons, and maybe 3/4 tons, but I don't know for sure.
  3. bshewmaker
    Sep 11, 2003
    79
    Arkansas
    thanks divorced.
  4. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    as far as I know you will need 3/4T or 1T springs pre-88, like divorced said. You can fab lower spring hangers but it's probably easier to do the 4" lifted rear springs like you are planning.
  5. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I dont know exactly how long the springs are but if they're as long as i think this is what i would do. Make a good solid bumper and make some 4" drop hangers, that'll get your 8" of lift, i know you can flip the spring around 4" more of wheelbase. You could also just order some 56" long 4" lift springs from ORD.
    Later
