56" springs and Shackle flip location
Discussion in 'OffRoad Design' started by juanblzer, Feb 22, 2002.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    56\" springs and Shackle flip location
    Stephen,
    I just picked up a set of chevy 56" springs. I already have the shackle flip in the rear and I was wondering how far back I should move it. Can I run longer shackles with them? Do you know of anyone that makes stronger than stock rear shackles? All your help is greatly appreciated.
    "chrome sucks"
    "you tried your best and failed miseralby...the lesson is never try" Homer Simpson
    "If it ain't broke, fix it until it is"
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: 56\" springs and Shackle flip location
    Shackle angle is a pretty big subject to jump into, first thing I'd try is just turning the flip around on the frame. Personally I think it's too much shackle angle and I know it will give you stiff compression travel. After that I'd look to move the flip back to match the "stock" flipped configuration, ie., move the flip kit back about 4".
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you want to try the longer shackle thing look for some "lowering" shackles...remember in the stock position a longer shackle lowers the truck.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
