56" springs on a 1 ton k5?
Discussion in 'The Garage' started by Pvt. Maggot, Jul 21, 2006.
  1. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    I can't find any info on this, I need to know everything I need to do to put 56" rear springs on my k5, found a nice all spring 4" lift, but its for a 3/4 ton. any help would be great, thanks guys!
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    56" springs have the same length from front eye to center pin as 52" springs. just have 4" more out the back side of the spring pack. so basicly you just need to move the rear shackle hangers back to comp for the diffrence.
  3. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    What do the 56's come out of? Are those the ford springs, or are the 64's? Or are they both?
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    56's come in all 1 tons and alot of 3/4 ton burbs.
    They are a chevy spring.
    57's are fords
    63's and chevys
  5. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    So a 56" swap with my ORD shackle flips would simply involve new springs, and scooting the ORD's out ~4" depending on the shackle angle desired?
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    The ORD flip has the best of both words. When you do the 56" swap all you have to do is swap sides on the brackets. Only downside is you cant really tune your shackle angle without drilling new holes.
  7. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Oh I think I remember reading something about that. They did it for an all-around shackle angle IIRC. Basically what I would go for, pretty close to vert....
