56's in the rear
Discussion in 'The Garage' started by down4thakrown, Apr 26, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    how much of a lift will stock size 56 inch springs in the back give me if i were to move the rear shackle back 4 inchs? if youv'e done this had did it flex/ride? thx
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    with or without a shackle flip?
    If without, it will have no lift.
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    with a shackle flip.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The 56's create no hieght difference over the 52's. They are just longer and can flex better. Most of the flex created it due to the new shackle angle though.
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i got the 4inch ord shackled flip.so some 56's off a 1/2ton long bed stock and my shackle flip should give me about about 5-6 inchs of lift if i were to keep bout the same shackle angle? because the rear end of a long bed sits higher then the front. are 4wd and 2wd rear springs the same?? how much would the rear end move back like? an inch or two?
