56's installed, well almost (pics)
Discussion in 'The Garage' started by white-rhyno, Oct 17, 2004.
  1. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    56\'s installed, well almost (pics)
    Got almost done installing my 56's. Got far enough to drive it home anyway. Need some advice as what to do on the front hanger. Im sure it needs a little more bracing.
    There are two leaves and the overload missing out of that pack. It sat down ALOT lower than what i had expected. I think ill throw one of my old BDS leaves back in there. I have a lot to finish so dont flip me to much $hit.
    Enough talking
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Re: 56\'s installed, well almost (pics)
    looks good, bit I think I would try and move that front hanger forwrd more, that spot only really works with the 52's. But I bet they flex like mad /forums/images/graemlins/thumb.gif
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Looks good. You could move the unused brace from behind the body mount to in front of it, but it looks like the winch mount bracket would be in the way.
    Are your headers welded directly to the exhaust pipe?
  4. white-rhyno
    Jan 27, 2002
    942
    I looked real hard at the L bracket, im convinced it wont work. Sick of getting those rivets out anyway....
    Of course my headders are welded directly. I hate leaks and that eliminates that one.
  5. divorced
    Jul 20, 2004
    5,115
    That's cool. I have mentioned this as a fix for leaky gaskets but everyone thinks I am crazy. My exhaust doesn't have any clamps, it is fully welded all of the way to the back. The only gaskets are where it bolts to the head; maybe I could weld that too... /forums/images/graemlins/thinking.gif
  6. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    what does this give u for a lift?, how long are the shackels?, also how far does this move the axle forward?
    sorry for all the questions, i just have a spare set of 56's laying around and want to put them in the front
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yo Dog, LOOKS GOOD! I understand more now after seeing the pics what you were trying to describe on the phone earlier. I wonder if you could round up a couple pieces of 4" or 6" angle iron, and move that entier front hanger forward another 2"? You could center your zero-rates if you didn't wnat your axle that far forward, and it would stand your shackles up just a bit more and give you a touch of your lift back probalby. I am sure that Juan can hook you up w/ a few pieces of whatever you need! or just ditch that stock spring mount all together and have Jim or Juan build you a new one out of flat steel that you could mount to your 3 winch mount bolts! That would be sweet.
  8. white-rhyno
    Jan 27, 2002
    942
    For lift? i dunno, not enough currently, could be cause im missing a couple of leaves. Ill let you all know how it turns out next week. Its supposed to be about 4"
    My shackles are 7.25" hole to hole.
    My axle is about 3.5" forward due to the zero rates, i think its like two without.
    My only recomendation would be to try using more leaves.
    I like this swap better because you dont have to move the shackle mount forward to get a good angle like you would with the 52's.
    Also my front hanger brackets are swaped from side to side. They seemed to sit flatter when bolted up.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i took the entire mount off of mine, zipped the 8 rivets off of the frame, and swapped them side for side, braces and all. i think im going to zip the hangers off of the mount brackets, and andgle the braces a bit. you may be able to work a similar brace in by bolting a piece of flat stock to the mount, and then gusseting it to your winch mount.
    isnt the goal of the whole swap to gain flex? if you go adding more leaves to your pack, isnt that defeating the whole purpose of the swap? /forums/images/graemlins/dunno.gif
  10. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Im having the same problem right now in fact my bumper and the bolts are in the exact same place, and I want to run 56s or 52s up front so if you figure it out let me know b/c I really want to run that setup and were did you get your shackle from /forums/images/graemlins/confused.gif
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You gain the majority of travel in droop, not in compression. So an extra leaf or two isnt going to affect it that much. I ended up making a new bumper and bumper mount setup when I went with the 52's in the front. It was a total PITA but it works so I dont complain. I've been trying to find a set of 56's for a long time around here but cant find any. I think they should work bitchin but im going to need new brakelines again, and I dont even know if my 14" travel shocks have enough travel for the 56's in their current location. Oh, check out my site for some pictures on how I mounted my bumper. I still need to figure out a way to mount my M10000 up there.
  12. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Brads shackles came from the same place as mine... a machinist buddy made them for us! They are pretty sweet and have the "spacers" built in so that you don't have to add flat steel or washers when you put the rear springs up front, and they are machined from a chunk of 5/8" cold rolled steel.
  13. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    damn ive been looking for shackles like that for a while maybe I need to make a trip up there /forums/images/graemlins/thinking.gif /forums/images/graemlins/rolleyes.gif
  14. white-rhyno
    Jan 27, 2002
    942
    I can get another set made MABY, i have no idea on what he would want for $$$ though.
  15. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    do they make 2 inch lift 56's?
  16. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    You know that if he is going to make more of those that Shane is going to want a set... /forums/images/graemlins/whistling.gif
  17. white-rhyno
    Jan 27, 2002
    942
    yea, he did ask a long time ago.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You don't need spacers anyway. Tim's Offroad has the bushings so that they'll go in and fit...without the use of spacers. /forums/images/graemlins/thumb.gif
  19. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ... but they look really cool w/ the spacers machined into them... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/woot.gif
  20. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    ya and looking good is a priority with our rigs /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
