56's or 57's up front
Discussion in 'The Garage' started by rubbinz raczn, Jan 2, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    hey putting 63's in rear so putting at least 52's up front. say i want to run 56's or f%rd 57's up front any big no no's why not? :xmas:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have heard that there isnt much of a flex difference between the 52's and the 56's, just more work to get the 56's in.
    If it was me I would just run the 52's, they are so much easier to install.
  3. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    that makes it easy:D
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, 52s werent hard at all.
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Why are 56's any more work? I have 52's, White-Rhyno has 56's... mine were way more work... we both had to move the front mount forward 4", we both have 7.25" long shackles... only diff is I had to move my upper shackle mount forward 3" in the frame to have a decent shackle angle, and w/ the 56's White-Rhyno just left his alone.
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    yep! Thats how I mocked up my 52's and 56's... I needed the 56's for the rear so I just used the 52's up front and moved my frame shackle... 7.25" shackles also
    (edit for some pic whoring...)
  7. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Yea i spent way less time putting in the 56's. 8 less rivets i had to grind out......
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ow I thought you ahd to move the front mount even further forward, one huy on our local board did that but I guess he just did it for the increased wheelbase.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    so you saved 10 minutes... i have one of these...
    and a good drill... add a good quality drill bit, and a nice hole saw, 10 minutes and you're good to go.
  10. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I tried cutting the holes in my frame w/ a hole saw, and that was a joke... I would say by the time I removed the old shackle mounts, figured out where to move them to, drilled new holes, and cut the big hole I was in it a few hours and a few bucks in grade 8 bolts. Its not a matter of how much time/work it was, I was just saying that the 56's will go in w/ LESS work... even if you have a shop full of cool **** and it only takes you 10 minutes.
  11. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Ok, does one move the axle forward more then the other or will the 52's and 56's put the front axle in the same spot?
    JJlaughner, your the only one that I have seen move the upper shackel forward, unless Im mistaken. I assumed the weight of everything up front would push the shackel rearward.
    Does anybody else have pics of their front shackels with 52's?
  12. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    56's have the extra 4" all on the back side, so the axle will be in the same spot as 52's.
  13. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    You can see my shackle angle in this pic... and this is after I moved the shackle mount 3" forward. Shackle is 7.25" long.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've done it
    Tim's Done it.
  15. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    white ryhno do you have a pic of your pinion angle
  16. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    and you guys w/ 56s and 52s do you like that shackle length or would you go shorter
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    mine hasnt had the full weight of the truck on it yet, as it has no engine or trans or front clip on it. Tim's seems to do pretty good there, but with his Superlift(?) 6" springs, his pinion angle points towards the ground a little more than i'd like mine to. i think if i put some weight on mine, i'll be just fine. its pointed a few degrees up towards the transfer case area right now, and should go up a little more with weight.
  18. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Ok cool, lets see a pic with 56's on the front. I'd like to see the shackle angle in stock position.
  19. white-rhyno
    Jan 27, 2002
    942
    hmmm good question..... if i cant find one ill get one for you.
  20. white-rhyno
    Jan 27, 2002
    942
    only have a pic of the shackle angle. I can still get one of my pinion if ya want, curious as to why? I do have 4degree tapered zero rates in there.
