56's or 64's in the Rear
Discussion in 'The Garage' started by MTMike, Apr 19, 2005.
56's or 64's
  1. 56" 4" Tough Countrys + 4" Shackle Flip
    9 vote(s)
    17.6%
  2. 64" 5" Tough Countrys + 2.5" Shackle flip
    9 vote(s)
    17.6%
  3. 64" 3" Tough Countries + 4" Shackle Flip
    33 vote(s)
    64.7%
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Here's the poll, disregard the other post: :doah:
    I've been planning on runnin 56's in the rear, but the more I read the more I'm thinking maybe I should do the little extra work and go for 64's in the back. I'm looking for 7-8" in the rear to sit level over the ~6" in the truck.
    The truck is in the sig, and is a trail-only trailer queen - street manners are not a concern.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I say if you are going to go with a lift spring then defently go with the longer spring to get your flex back from the lift springs.
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    Im going to be running 64's with 4' shackle flip to get the setup correct, then when I can afford it I want custom 64's for some crazy flex.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    3" 63s and traction bar setup man.
  5. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    if you are doing the big swap don't be afraid! go with 64s :waytogo: one thought though mike, are you still running stock fuel tanks? when i did my 64" rear swap i used one of the fuel tank hanger bracket holes for my front hanger, so fuel tanks had to come out. are you planning on sticking with the side saddle tanks or do you already have a rear mounted tank? :dunno:
  6. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    yes as above tank problems might be there. if easy to find then get blazer tank and put in rear end. easy to make the brackets. if needed i can post up pics of the ones i built for my truck. just pm me for the pics.
  7. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I have one (passenger side) saddlebag tank in the truck. I would like to keep that setup for now, though I have a feeling that in the future a fuel cell will be sitting back there. It's not as big of a deal if the tank has to temporarily come down.
    The wife use the words that every guy loves to hear: "Don't skimp, make sure you do it right the first time" :woot: I'm gonna make sure I do just that :)
    Hellbent: how hard was it to pull the tank?
  8. sweetk30
    Nov 1, 2004
    25,544
    539
    8 bolts and wire for sender and ground and then the filler unit. 2 or 3 fuel hoses .and it drops out. and leave the tank on the brackets.
    also is all stock the nuts should be welded from the factory on the brackets. if not good luck.
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    The truck is so highly modified from the previous owner I have no idea what's in there... When it stops raining/snowing and when tree branches quit falling from the sky, I'll have to crawl around under there and see what the PO did when he installed the Holley Projection pump.
    Thanks for the info, and you've got PM.
  10. sweetk30
    Nov 1, 2004
    25,544
    539
    pmed you back. and i have some info for ya in there .
  11. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    both tanks out in 20 minutes. i was doing the hack and slash impact wrench thing :hack: bedspace wasn't an issue since i wil not be having one! sounds like a blazer tank is a easy swap though :D
  12. sweetk30
    Nov 1, 2004
    25,544
    539
    vary easy swap to blazer tank and if long bed the suburban tank is also easy with up to 40 gal swap. and just a fyi van tanks look close but not. 2" to wide for the old 73-91 solid axle stuff.
  13. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Go junkyarding and find some 2500HD 64s. You might find out that they provide enough lift for you with a 4" shackle flip. I got 4" of lift out of mine with a 2" shackle flip with 2 leaves pulled.
  14. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    personally i dont think flex is the answerall... sure your truck needs to articulate... but if your not gonna be competing... then 56s in back 52s in front with bumpstops, and youll be fine....
    *disclaimer* i didnt read any other posts... i just responded
  15. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Holy gravedigger :eek1:
    I went 52/56 back in May after I posted this. Best thing I ever did for the truck :)
    Mike
  16. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    lmao... thus the disclaimer in my post haha...
