57" ford springs again
Discussion in 'The Garage' started by shaun, Apr 19, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    57\" ford springs again
    I got my 57's and about ready to do the swap. The problem is they are 3 inches wide and my 52's are 2.5 inches. Now I know you can get a shackle to accomodate the rear (not sure where from yet do you?) but what about the front. How do I put a 3" wide spring in a 2.5" wide spring hanger???? /forums/images/graemlins/confused.gif
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Re: 57\" ford springs again
    I believe the 57's that everyone is using are 2.5" wide and from an early 80's F150. I don't think the 3" wide ones are the ones being used.
    Just curious, how does the center pin position compare to the Chevy springs?
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    they are the same for pin to eye and eye to eye, just a 1/2" wider. you gonna make your own spring plates??
  4. shaun
    Apr 22, 2003
    745
    I dont know yet. I am confused. I git some off a 80's bronco and some off of a 74 f100. Both are 57 from spring eye to spring eye and both are 3 inches wide?
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    you grabbed them off of a 4x4 instead of the desired 2.5" wides found on 2wd's.
    if you can modify your front rear spring hanger the 3's would probably hold up longer then the 2.5's tend to.
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I got some 3" ford 57" springs. Not installed yet, but I did notice that the spring hangars on the ford I got them from are very similar if not identical to the ones we have on our chevy's. I was thinking of going back to the JY and grabbing the front and rear hangars to use on the chevy. Hopefully I can get there this week. I guess the important measurement would be from the frame to the center of the spring? I'll report back if/when I find out.
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Would the springs out of a custom f-150 (thats what the emblem thing says on it) work? The truck is dead out in the yard anyway. I haven't measured the springs because I keep losing the tape measure. I'll try to take some pics tomororw so I can get some additional help with year and whatnot.
