57" leaf springs
Discussion in 'The Garage' started by jeremy91k1500, Dec 6, 2003.
  1. jeremy91k1500
    jeremy91k1500 Registered Member
    Jul 8, 2003
    13
    57\" leaf springs
    i'm doing research ona project i'm going to start shopping for mid-winter/early spring. i'm going to look for a SWB K10 or a Blazer. i want a flexy suspension setup that's not going to cost me an arm and a leg.m i've read alot about 57" Ford springs. what kind of mods do i need to do to install these? and how far off is the lift rating on them as compared to a stock Ford application (ie if i buy 4" lift springs they'll actually give me ____ lift)
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Re: 57\" leaf springs
    No one offers a lift spring for those. Looking back on this I should have gone with the 56" rears out of the 3/4 ton chevs.
    Reasons
    #1 - you can get lift springs for it
    #2 - They are stiffer (less axle wrap and a more balanced suspension)
    #3 - Doesn't require drilling or offsetting because front eye to pin is the same as the 52s.
    But then again they aren't that bad. Im still running them because to me its not worth the energy to swap.
  3. jeremy91k1500
    Jul 8, 2003
    13
    3/4 ton springs are out of the question. stiffer springs = less articulation, and i want a lot of that...
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Any shackle flip is gonna give you an ass load of rear travel anyway.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    All you have to do is remove a few leaves to get the 3/4 ton leaves softer. They come with like 10 leaves in them!
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    My 57" ford rears bent on the passenger side form torque.
    Do you want buy them? /forums/images/graemlins/laugh.gif
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Mine aren't bent yet, but I wouldn't run open clamps with them. I will be adding at least one leaf to the pack though, with the hardtop on it sags a little.
    Axle wrap I have whipped thanks to Bill and Sean at Az-Kickin...
    Rene
  8. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    Do you want a trail rig or a 4wheelparts parkinglot mall poser that can only go up a ramp?
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I'm doing it... I'm going to use, ORD zero rates, ORD 4" shackle flip, and will be adding a longer shackle.
