57" rear spring Q's
Discussion in 'The Garage' started by Tweetysuarus, Apr 6, 2004.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    57\" rear spring Q\'s
    I am giving it great consideration to doing the 57" spring conversion! I have 6" lift as now with stock 52's, echobit flip and a lowering shackle on a 12 bolt. Do I need a pair of 2" lift 57" springs to get the same amount of lift with 14 BFF?
    Thanx for any info,
    Bill
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: 57\" rear spring Q\'s
    stock 52's will be close tot he stock 57's for ride heigth. i actually got some lift out of the 57's but I don't count.
  3. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    So stock 57" springs will have approximately the same lift?
    Bill
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    yes I'm at the same heigth as I was with the stock 52's.
  5. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    You can build the springs however you want. I got 4 inches out of mine.
    BTW, something not mentioned frequently, but you might want to run them backwards, for an extra 4" of wheelbase!
    Also, get a spring clamp from autozone, or you will warp them faster.
  6. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    temporary hijack
    what do 57" springs come off of ?
    hijack over sorry /forums/images/graemlins/ignore.gif
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    furds
  8. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    What spring clamp for the pack? Got pics and part number?
    Bill
  9. shaun
    Apr 22, 2003
    745
    Any furd? Sorry to hijack again. I am going to do the same swap /forums/images/graemlins/ignore.gif
  10. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    willy, so going to 57' he will lose lift and return to stock heigth? im curious too. Im really curious what 63's would do in the front /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  11. shaun
    Apr 22, 2003
    745
    i have a 70 2wd f100. Will those work?
  12. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    F-150 57' Ford springs. Take a look at AK-57!
    Bill
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    measure them /forums/images/graemlins/wink.gif
  14. shaun
    Apr 22, 2003
    745
    thanks. sorry to hijack
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    he is runninga flip so he won't loose any heigth, he will actually gave lift since he'll need a longer shackle to accomidate(sp?) the springs. also 63's will not fit up front. unless you have a huge dock for a bumper to hide them under and don't mind hitting eveything you try to get over.
  16. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    What do you mean longer shackle to accomedate the springs???? I must be missing something here/forums/images/graemlins/dunno.gif?
    Bill
  17. shaun
    Apr 22, 2003
    745
    I was going to ask that same thing
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [​IMG] see how the longer spring sits behind the hanger now?
  19. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ]so running 57's in the front im going to lose my lift /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
  20. shaun
    Apr 22, 2003
    745
    So will the longer shackle now be like this \ ? How will taht work with axle wrap and ride quality?
