57" up front (pics)
Discussion in 'The Garage' started by 55Willy, Sep 23, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    57\" up front (pics)
    heres two pics of the ford 57"s in the front of my wagon(1977 k5 frame)
    [​IMG] [​IMG]
    I ground the old shock mounts off, moved the axle forward about 4"( due to the fords) and with the 8403' DT's the damn things bolted right back to where the stockers were,LMAO!!!!!!
    and yes the sway bar links are coming off.
    over all I gained 6-7" of lift out of doing them. funny how a spring 8" longer then stock "bolts" right in /forums/images/graemlins/pimp1.gif
    -Jeremy
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    Re: 57\" up front (pics)
    57s in the rear... 57s in the front... the rig sits kinda high... and you wanna get rid of that sway bar?! /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif I dunno dude... 57s are loosey goosey.
    j
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Sway bar had to come off for the crossover and since the axle is 4" forward it doesn't fit. I tried to mount the sway bar from the rear but I can't get a solid mount on the passenger side. I can always add a aftermarket sway bar kit but I'm not shitting $100 last I checked. /forums/images/graemlins/rotfl.gif
    plus I'll probably be adding a rear sway bar to help there. but I figure it ain't street legal, unless i build some mad max style mudflap/flares,LOL
  4. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Very nide! Have you tried to flex it out yet to see what it'll do? You could always go from some homebrew quick disonnect mud flaps to make it legal. Just a thought.
    Kris
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I'v had the high lift bumper jack under the tie rod and was able to max it out and the rears just started to move so there plenty there.
    When I put the rear end in I had to jack the back of the rig up about 60" (see note) to the frame rail and still had to pull the spring down to get the shackle bolt in.
    It's like wrestling with 12" lifted springs but these flatten out,LOL
    ** note:
    it was a 10" wide rim on its side, with my bumper (2") on that for a base for the jack, jack maxed out (48") and a piece of 2" tube under the frame rails.. 62"
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    What are 8403' DT's?
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    Ditto
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the DT8403 is the longest non-ressy shock that doetsch tech makes.
    they have built in bumpstops and about 12" of travel.
  9. yellowK20
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    Thanks /forums/images/graemlins/thumb.gif
  10. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Well, you finally got them in! So, did you jump on the front bumper and see how much it moves?
  11. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    are you going to support the outside of the bolts on your front hangers at all?
  12. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    any reason why you left the overloads in the spring pack???
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    no real reason.
    I still have to add my angled shims so I might pull them out then, see how it rides first. Although it would keep them from prematurely warping on me.
    also lazy and been two years since I'v been wheeling so I'm kinda doing a hit and miss here,LMAO!!!
  14. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I have jumped on it, it moves about a 1 or so, maybe more but I only weigh 170 pounds.
    and yes the outside is getting a plate too and braced upbetween the frame plate and the outer. and capping the ends once all the holes are in.
    -Jeremy
    ***** great news, I got my digi cam tonight so pics can come more quickly,LOL ***** (thanks Jeff)
  15. ccox7
    ccox7 Registered Member
    Jul 24, 2002
    69
    Bayou State
    What year Ford Truck did the Springs come off of ?
    Are you making your own front spring hangers ? I am getting parts together to convert my 2wd.Does the Ford Springs ride better?
    David-- New Orleans La /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  16. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the fronts are '77 rear springs.
    my front spring hanger is tied into my bumper, Yes I'm making it.
    the ford springs are way softer. not sure how they would handle in a "normal" rig.
    My front sheetmetal is a 1/4 the size are a K series. and my motor is moved back 4" and the axle is forward about 6"
