57's IN THE HOUSE
Discussion in 'The Garage' started by TONYP, Oct 13, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    57\'s IN THE HOUSE
    just picked up my 57" f**d leafs, got Neil sending my Missouri Offroad Outfitters differential cover and truss support. I'm (don't tell the wife) building this thing up.
    I'll be sanding blasting(the word f**d off) and painting the leafs (POR-15?).Then comes the traction bar... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Re: 57\'s IN THE HOUSE
    Right On! You wont regret the 57's, sweet ride! Congrats!
  3. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    sounds awesome man. sounds like someone went a lil spend money happy this weekend. later.
    jacob
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so what is the big benifit of these ford springs..ive heard a lot about them but im not sure what they are so good for cause they are 57" or something? will they bolt up to a k5 or do they require modifications..
  5. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    so mike when are you going to find me some 57s ??? /forums/images/graemlins/1zhelp.gif
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    I got these for $50.00, he had a fo*d 9-bolt that he wanted me to take too, not sure about that, it was 5-lug with drums....Is it worth anything? /forums/images/graemlins/ears.gif
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    Check this out
    web page
    /forums/images/graemlins/deal.gifANGLES ARE IN /forums/images/graemlins/rotfl.gif
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahh nice thanx!!
  9. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I've heard you shouldn't sand blast leaf springs...but I'm not 100% sure why /forums/images/graemlins/confused.gif
    Rene
  10. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Does anybody know the spring rate on those 57's? Wonder if there too soft to run on the back of a blazer prerunner.
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    They're under 200 lbs per inch. Mine had 9" of free arch and the weight of the truck ate up 7 1/2" of that.
    As near as I can figure the back of my truck weighs about 2800 lbs with the hard top. Subtract 500 lbs for the 14 bolt and another 150 lbs for tires and you have 2 springs supporting 2150. Unless I'm missing something that puts the spring rate at a little under 150 lbs/inch.
    I'd think they would work good on a pre-runner with some good long travel shocks.
    Rene
  12. TONYP
    Aug 13, 2002
    2,116
    so cal
    Rene,
    you put your axles back I think you said 1 inch. did your drive line have to change?
  13. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I drilled the 57's so I could keep the axle exactly where it was. 1.5" turned out to be pretty damn close. I do have enough slip yoke to move it back an inch if I want to though.
    The 52's have the center pin hole at 26". With a shackle flip the axle center moves forward a little though. My 57's are drilled at 26.5" from the front spring eye center.
    Rene
  14. TONYP
    Aug 13, 2002
    2,116
    so cal
    read the post one more time....got it!
    then you put on Echobits shackle kit and you added 4 to 5 in lift /forums/images/graemlins/k5.gif
  15. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Actually, Rene relocated his stock hangers and re-fabbed them to a compression style mount. Some slick work!
    Andy, I see them all the time, I'll grab a set if you want?
