57's up front (in progress)
Discussion in 'The Garage' started by shaun, May 13, 2005.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I just thought I would let you guys know how it is going. Old 4" TC's are out (and for sale) New 7" eye to eye shackles are bolted in. Front axle chilling while i slowly drill out 16 rivets. I tried everyway mentioned on this site and this one works the best. about a rivet every five mins. The pilot hole is what takes all the time. I wonder if my 10" lift brakelines will be long enough. HMMMMMMMM time to set up front brakelines like the rear ones. Well back to work 8 rivets to go. Woo hoo.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Are you gonna add any leaves to the 57's? I am running 57's in the back, and they are VERY soft... Might be almost toooooo soft for the front...?????
  3. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    if you want some serious brakelines, i highly recommend you contact kleithflux over on pirate and get some Crown Perf lines from him. I just got some 36" long Kevlar/stainless lines from him and they are freakin BLING. Not really that expensive either... cost me about $15-20 more than my procomp 4" lift stainless ones did... though I didn't get a rear line and the PCs came with one.
    j
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm going to setup my front brakelines with a center drop(like you noted). Not a fan of having 2 huge lines on each side that could get caught or whatever. Single center is easy and cheaper IMO.
  5. shaun
    Apr 22, 2003
    745
    Poohbair I am not adding any leaves. Just 3 leaves and an overload. Hope that works out. I thought about 2 overloads each but I dont know If that would work.
    Jekbrown I will ahve to check out those brakelines on pirate. I am going to try and do the center drop first though. Thanks for the idea
    Sled dog I am hoping I can make that work b/c I wont be able to flex until I figure this situation out. It shoukd be relatively simple though. I hope.
    Well 6 rivets to go. This really sucks
  6. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    even if you're just doing short lines... these things rock. :) i aint worried about them caught on stuff, Im taking a page from the buggy guys and use a spring to keep them out of the way.
    j
  7. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    what are the 57s from? what vehicle could I get some from? could you post some pics of the mods that you have to do?
  8. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    they are stock furds.
    j
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, but off of an f150 or what?
  10. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    not 100% sure... i thought they were stock F150 rear springs... not sure what years though. I recently purged my GM of its lone ford part... I try not to think about adding others. ;) In all seriousness, 56s/63s are hella flexy and the right width, so thats why i never looked at the 57s.
    j
  11. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    mid 80's f150 I believe....2.5 inch wide....there are 3"ers also
  12. shaun
    Apr 22, 2003
    745
    Well the swap is done. The 57's are from a 1970 ford. With no weight on it (jack under the frame) the front sat about 5 inches higher. But when we put the the frame down on the springs the whole truck sits level (well the front is about 1/4 to 1/2" lower) but it is perfect. I didnt add any leaves and it feels nice
  13. PsychoticDeadGuy
    Jan 8, 2005
    753
    Hey, sounds good. Could you post pics or something for other people that want to try the swap? I think 57s would be a better idea than the 52s that I was planning on. So the whole swap gave you a 4" lift over stock?
  14. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    my 57's are from a late 80's F150 2wd
  15. gaspass
    gaspass 1/2 ton status
    Apr 24, 2004
    185
    Pocatello, Idaho
    springs
    how much for the tuff country springs? are they saggy?
  16. shaun
    Apr 22, 2003
    745
    I will post pics tommorrow. Still having issues.
  17. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    The 3" wide ford springs kick ass when used up front. They are soft like 52's but because they are wider they don't bend/kink/brake. I have a writeup floating around here and over on pirate if anyone wants to see details...just search under my name.
