6.2 1 ton Diesel Radiator in a K5 w/350 motor ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by californiak5, Aug 26, 2001.
  1. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Can it be done? Has anyone done it? If it has been done, what mods are needed? Any and all help is greatly appreciated. Thanks in advance.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It could definitely be done if you changed the core support, otherwise, come up with a way to fasten it down.
    I believe that it's wider than your stock one.
    I was going to try it but the radiator I was going to use turned out to be junk.
    Tim
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Actually, I dont believe you need to change the core support. My 6.2 has two threaded holes for a smaller 3 core radiator mount and every gas powered truck ive ever seen has the two threaded holes for the bigger diesel radiator. Im sure it would just be a matter of moving the upper tie down and getting the correct mount for the bottom and then a new shroud to match the bigger radiator.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I'm using the stock 6.2 radiator and shroud w/my 350. It is wider, and I've noticed the same thing about the mounts. Radiator hoses is the other problem, the inlet and outlet are bigger than the gas radiators, and the upper hose has to be longer. I think I used a 350 hose on the bottom, and the top hose is for a '72 Firebird w/ a 400 motor. I had to stretch both hoses onto the radiator. I've also seen guys splice two hoses together for the top one, this may not be a bad way to go. Maybe a diesel hose and a gas one, spliced w/one of those exhaust adapters (bumped up on one end).
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I had this setup in my K3500 w/ a 350 Swapped in easily. I believe I reused the bottom and top supports. Used the original bulkhead
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  6. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Hey Kieth,
    Steve_87k5 sent me this message once when I asked about the same thing
    The diesel rad has 2 internal coolers. One for ATF and one
    for engine lube oil. Also 2 bungs for sensors. When you connect your
    engine oil to the cooler, be careful. The tank metal is very thin and if the
    hoses vibrate and hang out too much it will crack the tank.
    I custom made a 90 dergree fitting so the hoses go straight
    down and don't weigh on the tank. I used
    oil fitting 3/4-18 UND #8 Weatherhead tubing nut and silver soldered to it
    and used O ring to seal to the bottom of the rad bung.
    plastic cover for fan GM 14039948 panel
    rad hold down bracket R GM 14039950 bracket
    rad hold down bracket L GM 14039949 bracket
    rubber mounting pads GM 6264100 pad
    My rad is model IR2098
    Good luck and thanks Steve...
    Jeromy
    Surfing is Life...
  7. californiak5
    Oct 25, 2000
    820
    Hey, thanks for all of the help guys. From what I am getting here is that it can be done and is not to hard providing you have all the supports and shroud and such.
    Sounds good. Anybody else have any info on this swap?
    See Ya,
    Keith
