6.2 Block and 6.5 Pistions
Discussion in '1982-Present GM Diesel' started by josephn, May 24, 2002.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    Does anyone know if you can or is it possible to bore a 6.2 block to 6.5 blocks dimensions? And then use the 6.5 pistions?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The only 6.2L block that can be safely bored to a 6.5L bore is the 599-casting-number block. This is the "transition" block used by GM when they went from 6.2L to 6.5L. This block is essentially a 6.5L block that was only bored to 6.2L standards.
    The earlier 6.2L blocks don't have enough meat in the cylinders to allow them to bored that much.
    Casey
  3. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Where would you find this casting number on the block???
    Thanks in advance.
    Mike
  4. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Try at the back,behind the drivers side head.I'm not sure what number it is.Check also the passenger side,I'm remembering that there is also some numbers.
