6.2 build up with turbo
Discussion in '1982-Present GM Diesel' started by blaz_mem, Aug 2, 2005.
  1. blaz_mem
    blaz_mem Registered Member
    Jul 21, 2005
    36
    Louisville, Ky
    Can anyone give me advice about using a turbo off of a 6.5 diesel. I am rebuilding my 6.2 and am going to turbo it but dont want to fork over the money for the banks kit. I also installed a 14 bolt with 4.10's and a 4 inch suspension and 35x16.5's.
  2. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    Basically take the 6.5 turbo and exhaust manifold and bolt them onto your 6.2 and turn up the Injector Pump to compensate. Make sure you install EGT and Boost Guages. Depending on the block you have you my concider installing a 6.5 head gasket to lower your base compression slightly ... as you are inceasing it with the turbo.
    Surf around over here http://www.thedieselpage.com There is lots of info in there forums and online documentation ... you may need to become a member to gain access to the online doc.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    There is an interference issue with the 73-87 style AC housing and the 6.5 TD turbo location. Some people have modified the housing or swapped in a S-10 housing/AC evaporator. You have to fab up a oil supply and return for the turbo.
  4. blaz_mem
    Jul 21, 2005
    36
    Louisville, Ky
    hey thanks alot guys
