6.2 compression???
Discussion in '1982-Present GM Diesel' started by steve_kibbe, Sep 14, 2004.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    What should the compression for a 6.2 diesel be??
    I was going to repalce the injector pump, but wanted
    to check cylinder pressure first. I have the tool, but
    haven't doen it yet.
    Steve
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    IIRC all cylinders should be within 10% of each other.
    Also, Make sure that the tester you have is for a diesel!!!
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    A new engine can show over 400 PSI, the lower limit per GM is 300 PSI i think.
  4. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I am testing it cold, It doesn't look to good. Getting
    readings between 60 and 240 psi. I'm going to try to reckeck with some oil in the cylinders. Blown head gasket? Bent rod?
    Any sugestions?
    Steve
  5. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Don't put any oil in the cylinders! It's not safe to do that on a diesel. They don't call them "oil-burners" for nothing!
    There is a very remote chance that the engine could fire if you squirt oil down in the cylinder. It's not very likely on a cold engine, but it is still possible. If that happens, you could damage the engine and/or damage your guage.
    Also, there is very little space between the pistons and heads. If you squirt too much oil in there, you could hydraulic-lock the engine.
    It's a safe, common practice to do this on gassers, but I wouldn't do it with a diesel.
    Casey
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    thanks for the tips, I do have all the glow plugs out, will it still fire?
    just thought the oil would help the rings.
    Steve
  7. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,036
    1,095
    Dallas
    With the glowplug hole open and the combustion chamber exposed, you will not be able to build enough compression to ignite the diesel.
  8. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    List all 8 cylinders and their value. How long has the engine set before you go it?
  9. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    My '91 GM manual states they should not be below 380psi. We had a 6.2 that was in the 310-320 range and didn't start worth diddly when cold.
  10. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    before it sucked water, it did start hard when cold, I will re-check the cylinder pressure tomorrow and list them. I know the 2-8 side was alot lower than the 1-7. I believe #4 was 60psi, and #3 was 240psi. I will list them all.
    Thanks for y'alls help.
    Steve /forums/images/graemlins/thumb.gif
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would assume you have bad heads but could also be rings.
    If you have these low numbers it's no good.
    Mine had consistently 230-240 in all 8 and still doesn't start.
    300 I think is reasonably the lowest you want.
