6.2 crank is now in two pieces......
Discussion in '1982-Present GM Diesel' started by 84CUCV, Apr 8, 2003.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I am kind of worried now. It was pulled from a 84 k5 like mine. Two of the places where the crank rides (can't think of the name right now) are broke also in like a v shape and I can pull them right out. How does this happen and how can I make sure it does not happen to my new motor? Thanks Mike
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Best guess, it was the harmonic balance that was bad. That crank in a 6.2 is doomed once the balance comes apart.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Is there a way to check it and make sure it is in good shape? Mike
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Inspect the rubber cushion between the inner and outer part of the damper, maybe check the runout with a dial indicator.
