6.2 diesel guys, Batteries? Rene?
Discussion in 'The Garage' started by Zeus33rd, Feb 11, 2005.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    My "new" dd has the 6.2 diesel and needs a couple new batteries. Been sitting foreeever- old ones just won't hold a charge. Any reason not to go with Optimas? Red or Yellow top? Or should I stick with a more concentional battery for the 6.2? I want whatever will be the best.:D
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    AC Delco is what I use. Good but expensive. Well worth it IMHO.
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I just got a pair of Red Tops this winter and it helped cranking speed slightly with ambient temps below 10 degrees and otherwise no problems yet. A diesel doesnt require any special kind of battery, but the more cranking amps you get the better, thus the two battery setup in them.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I'm just not convinced that the Optimas are really worth it, especially for a DD. I guess if money is no issue, go for them, but my 6.2 has been running on the same pair of Duralast Gold batteries since '96 which are about half the price.....................................
  5. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    An employee at my local Interstate battery store told me Optimas don't like being charged up rapidly. He said that if you run one down you have to slowly recharge it, I think it was because they get too hot trying to recharge too fast but only IIRC. From there rep. they are good batteries regardless.
    I personally would go down to the local Interstate store and get two 700+ CC econo batteries, you can't beat $20 for a battery, especially of that size.
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Go get two of the biggest batteries you can. I run 750CCA's and in winter am wishing for more.
  7. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I run two AC Delco 1000 CCA batteries in mine. Great ing speed even when it's cold out. Most important is to replace both at the same time and use identical batteries.
    Rene
  8. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    mine has what came in it!
    My 82 K20 has 2 duralast batteries that came in it when I bought it--one is a duralst "gold",and the other is a plain "duralast"--they dont appear to be very "big" either,I'm not sure of the "group" size,but they dont appear to be as large as a group 74 that usually comes in GM trucks--
    I wasn't aware they should be a matched pair,I thought as long as one battery doesnt have a bad cell and suck the life out of the other one was all that really mattered--hasnt affected mine so far at least--It cranks over fine even in the sub-zero arctic blast we had last month,I figured on just using theese batteries up,or perhaps I'll swap one into my van and 79 C10 and buy 2 new ones for the diesel --if I ever find a job and have money again..:frown1:
    .I dont think I'd buy an optima battery though--from what I've heard about them on the web,and my friends experience with his yellow top,I think I'll buy 2 "old fashioned" lead-acid batteries for the same price as 1 optima--and I'll see if I can stuff a bigger than stock battery in the tray when I do it...I'm leery of the optima's design,its not "proven" yet in real world conditions if you ask me--looks good in the lab tests though...:crazy:
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thanks for the input...I kinda figured the Optimas wouldn't be worth it. Guess I'll go look for a couple 1000cca conventional batteries. :)
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Two conventional wally world batteries for me. works great. Two is betta that one.
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I'd say that 6+ years of use in the Navy and Marine Corps' aviation ground support equipment, in environments ranging from the Arctic Circle (Norway) to the sandboxes (Iraq and Afghanistan), to the high seas (all Navy aviation ships - CVN, LHA, LHD, LPD, LSD), and everywhere in-between, proves pretty damn conclusively that the design is sound and is tolerant of most abuse. But hey, that's just MY real-world experience....
    If you winch a battery dead, especially without the motor running, you're gonna damage ANY battery. They're just not designed to be discharged to nothing by having the amps ripped out of them with a winch.
  12. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    i dont know???
    The main problems with the optima's I've seen and read about is they go dead while sitting more than a few weeks--recharge them and they will crank all day,or until the starter melts--but let them sit idle,and they will go dead--i realize any battery will,but the 4 out of 6 people I know or heard of that had them have had this problem with them,and arent happy with them because they are advertised to start a vehicle that has sat for 2 years(a bit overkill perhaps,but thats what their ad says!)--but the places wont warranty them as defective as long as they recharge,so they feel they got ripped---I have read many similar reports on the web too---I'm not saying your wrong!-:crazy:
    I'm sure the military wouldnt buy them for their vehicles if they werent up too snuff(at least I hope all the humvee's start if and when we need them!:blush: )--but they havent won me over yet--for now,I haven't got 150 bucks to shell out for 1 battery,when I have 3 vehicles that sit quite often more than get driven a lot..maybe after they have been around a few more years I'll see how their reputation is then--maybe its just a fluke or a bad batch of batteries that had bad cells or something??:confused:
  13. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    i ran two duralast gold 1200 cca's. They were great, but after exactly one year they stopped holding a charge. The new one's they just gave me to replace only had 800cca's and they are almost dead now too after only a couple months. I love warranties.
  14. Spkrman
    Spkrman Registered Member
    Jan 23, 2005
    39
    Matteson, IL
    the best budget buys:
    everstart MAXX from walmart
    interstate workaholic
    With everstart you get a no Q"s asked warranty... so just bring them back every year and they will replace them for you... not to mention, they are pretty good batts.
    Interstate makes some kickass batts for the buck, I use the workaholics in my monte carlo and they are about on par with a regular yellow top, for much cheaper.
    The best battery as far as cranking/reserve/$ is probably hawker - they make stinger's batteries... the 2150 is just a *beast*. The optima group 31 is no slouch, but doesnt have big CCA.
  15. BlueBlazer
    Feb 15, 2001
    1,940
    They have been around for over 10 years, that isn't long enough for you? Also, only the yellow tops are 150, the reds are around 100, which is only 30 bucks more than a comparable conventional battery.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Interstate batteries are made by the same company as the batteries sold at Autozone.
    Most GM trucks come with a group size 78 from the factory...which is the same as a group size 34, just has side posts. Some newer batteries like mine will be called a 34DT or 34/78DT which means they have dual terminals and can be used for both.
    I think everyone knows that I don't care for Optimas so I won't go on another rant.
    If anything, I think the military would use Optimas because of the mounting options and because they're 100% sealed.
    I've been around many a military vehicle that wouldn't start when needed....luckily we had slave cables for EVERY vehicle quickly available...plug it it, wait a minute, slave vehicle #2 off #1 and you're done.
  17. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    I have dual Red tops mounted behind the cab of my truck. The 6.2 turns over much faster than it did with the old 24 volt system. My truck gets driven a couple of times a week and has sat for long periods of time. I did have ground problems at first but now it works perfect. I couldn't be happier.
  18. Spkrman
    Jan 23, 2005
    39
    Matteson, IL
    and those are also some pretty decent batts :)
  19. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I had Duralast Golds in my 6.2 since I got it, and they had been in our combine before it, so they had been through, hell, I just replaced them last summer.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I know, I have two JCI batteries under my hood right now. :grin:
