6.2 Diesel Hydro Boost Pump to '73 350 SB
Discussion in 'The Garage' started by 73k10sub, Mar 18, 2003.
  1. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    6.2 Diesel Hydro Boost Pump to \'73 350 SB
    I finally got the engine back from the shop and trying to mount things (putting a 350 in a former diesel CUCV one ton). Has anybody mounted the diesel hydro pump on a gas SB? I have what GM calls the "P" model pump which is the tear drop shaped one without a remote resevior. A junk yard search has not turned up a one ton gas SB with hydro boost.
    /forums/images/graemlins/1zhelp.gif
    /forums/images/graemlins/truck.gif
  2. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Re: 6.2 Diesel Hydro Boost Pump to \'73 350 SB
    The pump is the same size (with 1 extra port in the side) as a standard Small Block PS pump. Use the 1/2 ton brackets & pulley on your existing pump.
