6.2 Diesel low oil pressure
Discussion in 'The Garage' started by mountainexplorer, Apr 24, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    When a 6.2 Diesel suddenly drops oil pressure readings to the 7-15lb range (when before it ran between 30 warm to 75 at initial start up) what could it most likely be?
    Gauge/sending unit?
    Oil Pump or component?
    Crank or motor internals going bad?
  2. tRustyK5
    Jul 23, 2000
    36,164
    1,361
    E-town baby!
    Mine had a bad guage in the panel. Was reading 5 psi at idle and maybe 7 psi at cruise rpm. Swapped out the guage and it reads 65 psi cold and 45 ish warm at cruise rpm.
    Rene
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Thats kinda how mine is. It's like it still reads but just not very high. I'm hoping it's just a gauge. With all the knocking a 6.2 makes anyway, it's hard to tell if anything's making noise from the bottom end.
    I've run it this way for a while, and I figure if it truly was that low something bad would have happened by now.
  4. tRustyK5
    Jul 23, 2000
    36,164
    1,361
    E-town baby!
    Try transplanting an OP guage and see if things change...lord knows you must have a few dozen to choose from. :D
    Rene
  5. mountainexplorer
    Nov 14, 2001
    4,903
    I guess theres no difference in oil pressure gauges from diesels to gas motors. But I wonder if the sending units are different or if the sending unit could be whats acting up.
  6. tRustyK5
    Jul 23, 2000
    36,164
    1,361
    E-town baby!
    Well...the diesel OP guages are sposed to be 0-80 psi instead of 0-60 psi. Find one and chuck it in...if the gauge shows the needle in the middle that'd tell you it was a gauge problem and that the oil pressure is ~40 psi. I used this method to confirm i had a guage problem...then went out and bought aftermarket guages I can actually trust. One day i might actually put them in the truck. :p:
    Rene
