6.2 diesel question?
Discussion in 'The Garage' started by hidesertwheelin, Feb 19, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I am looking at a 85' Suburban witha 6.2 diesel in it as a tow vehical. I don't know anything about diesels :confused:. How many miles do they last? What problems should I look for? How much are they to replace? Thanks for any help.
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    If the engines are taking care of I know the 7.3L, 6.9L and 6.0L Ford diesel engine can last from 300,000 - 500,000 miles. The same goes for the 6.2L if it has been taken care of.
    Adam
  3. velocitiii
    velocitiii Registered Member
    Dec 19, 2003
    54
    You might want to read up on the 6.2 a little more on the diesel section before you drop those coins. The 6.2 isn't a "real" diesel in that it is basically a modified small block. They don't seem to hold up as well as the other engines designed as diesels to begin with.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    This is true. The 6.2L is not a very good engine. BUT I have seen more then 1 6.2L with over 300,000 miles on it and it was still going strong.
    ADam
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 6.2L is a real diesel - it just isn't a PSD or a Cummins.
    I'm happy with mine. IMO, it tows as well as a 350, just not as quickly.
    Decide what you're going to do mostly. The 1/2-ton with the OD will get great economy when you're running empty, at the cost of towing capacity. The 3/4-tons usually don't have OD but the axle gearing are brakes are much more favourable for towing.
  6. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Exactly. The 6.2 is NOT based off of a "modified" small block. It was designed as a diesel and will last a long time if taken care of. Read some of the posts in the diesel forum here. You can easily get more power out of a 6.2, and have quite a bit more power then a 350, and will do a decent job towing anything that a Sub can handle.
  7. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Amazing how that myth persists...
    The 5.7 is the diesel engine you're thinking of and was based on the Oldsmobile 350 at the time. They did modify the block, but as you know the motor still had a lot of problems (although some did run for quite a while)
    The 6.2 was designed and built for GM by Detroit diesel...from the ground up.
    For towing I think the 6.2 could be decent as long as it was geared low enough like the 3/4 and one tons were. A 1/2 ton with high gears and OD tranny is probably going to be a poor choice. The 6.2 doesn't mind revving...
    Rene
