6.2 diesel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevy4x4, Jul 10, 2000.
  1. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Hey,
    Anyone know what kind of m/g would a diesel blazer get with 35s and stock gears??
    <font color=red>Chevy4x4<font color=red>[​IMG]
    http://fourbyfour.coloradok5.com
  2. mike race
    mike race 1/2 ton status
    115
    Orlando, Fl
    about 17-21 mpg
    fix'n finally
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I have an 83 with a 6.2 and 3.42 gears with a 700 and 33s. I get about 20mpg average. I have to tell you though, the motor is so underpowered I can't put it in overdrive till I'm over 65mph because the rpms are pulled down so much (1340rpms at 55 mph). It's so slow in fact I'm thinking about slipping in a 350. I think all diesels were 3.42 geared, unless it had an optional rear. I would 4.10 the truck at least with 35s.
  4. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    It really needs a turbo. Adding one to a 6.2 is a good idea and not difficult. They do very well with about 7psi constant boost. The stock 6.5 turbo passenger side manifold is a bolt on and any of several turbos fit the flange. If you have A/C you will need to surgery on the A/C housing for clearance or find a van A/C housing. Another idea is to buy a bolt on kit from Banks.
    SteveB
  5. JimmyDie6.2
    Jun 20, 2000
    453
    Long Island
    You could also use van injectors if you have an ac truck, for clearance purposes. JS
