6.2 diesel ?
Discussion in '1982-Present GM Diesel' started by 4x4k20, Aug 17, 2002.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i just bought an 84 m1008 its been sitting for a while so i know its going to be hard to start back up what do i need to do? to get it going again such as how do i bleed the air out to get the fuel to the injector pump say it just like i have ran it out of fuel
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Id just loosen an injector line and crank over a little at a time and wait for fuel to come out the line then close the line.
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    How long is "a while"? I know of a few Diesels that set for months and fired right up.
  4. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I knew a guy that installed an el cheapo inline fuel pump under the hood before the filter to prime up to the inj. pump. Saved a headache or two.
  5. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    If it's anything like mine, with the square fuel filter on the firewall, you just open the bleed valve on the fuel filter assembly, pull the pink wire off of the injector pump, and start cranking.
    Crank the engine off and on for ten seconds at a time, watch for fuel to come out of the bleed valve on the fuel filter. Once fuel comes out, close the valve, reconnect the pink wire, and it should fire up after a little more cranking.
    At least, that's how it works on my truck. /forums/images/icons/wink.gif
  6. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    HEY!!!!! thats what my hanes manual says. i just replaced that fuel filter mine wouldn't start i bought my manual and what Danno said is right to the best of my knowledg cause it worked on mine
  7. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I did what danno said worked for me. Mike
  8. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    thats what i will try first i have never worked on a 6.2 before the truck has been sitting for 2 years or longer i really dont know it only has 145 miles on the speedometer the engine even looks new but i want to hear it run.
  9. Danno
    Aug 4, 2001
    487
    Rockford, IL
    Yup. I read that out of the blue Haynes diesel repair book, I think. It's been a while since I changed a filter... /forums/images/icons/smile.gif
  10. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    if you are bleeding air out of the system, you are supposed to open the bleed on the filter block and unplug the injector pump so you dont pump the air into the pump. You can air lock.
  11. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    update i finally got a key for it and went out there today and tryed to start it it fired rite up all i had to do was bypass the key switch because for some reason the switch is not sending power to the starter
  12. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Told ya it would fire right up!!!
