6.2 fast idle sensor question
Discussion in 'The Garage' started by cucvzee, May 22, 2005.
  1. cucvzee
    cucvzee Newbie
    May 22, 2005
    NJ
    Hello,
    I recently got an '84 military 6.2 diesel blazer and ran into this problem....... The fast idle solenoid fails to energize at cold startup.......I traced the problem to what the manual i got with the truck referrs to as a temp switch located toward the rear of the block on the passenger side (its a small screw in sensor wth two prongs-- one gets power from the ign switch, the other goes to the fast idle solenoid)..... According to the book i have, this thing is supposed to remain closed when cold and open at a set temp thereby cutting power to the fast idle solenoid. My problem is that when i tried to get this part from a local supplier they looked at me like i had a third eye when i referred to it as a "fast idle switch" -- A local mechanic told me that this thing is most likely a #TX47 sensor but the parts store referrs to that as a glow plug sensor. Does anyone have any input as to what the correct name and part number for this little gizmo is?
    thanks
    Zee
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I believe that is called the "Temp inhibit" switch, and I think it prevents the GP's from cycling when the truck is warm too. Might want to try the Stealership for that item.
    Rene
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Try temp switch for the HPCA (high pressure cold advance) on the injection pump. It controls that in conjunction with the high idle solenoid. Did you get the parts TM also? It should list a manufacturer's part number (that NAPA can cross reference).
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You're giving it 1/4 throttle when you start it right? If you don't, it won't engage.
